Please let me know how you draw your's out.
I am aware of Eagle, PCB123 and CAM350.
I need to be able to custom draw the pads, in Metric, to a resolution of 0.01mm, as the board will be populated with fine pitched SMT.
The easer it is to use, the better - I don't have the time for another vertical learning curve.
Hi John,
If you want on the cheap and quickly on the run (almost no learning curve):
Sprint-Layout
It is just a plain PCB drawing program, I would not recommend it for big designs.
Cheers 😉
Sprint-Layout
Cheers 😉
Arn't Expedition and Allegro very expensive? Do you know approximately what they cost?
Here are a few more links:
http://www.edwinxp.com/
http://www.labcenter.co.uk/
http://www.expresspcb.com/ExpressPCBHtm/Costs.htm
http://www.cadsoft.de/ (runs on Linux)
http://www.olimex.com/pcb/dtools.html
http://etronics.free.fr/dossiers/softs/soft00/logiciels.htm
http://bach.ece.jhu.edu/~haceaton/pcb/ (Unix/Linux: free)
http://pcb.sourceforge.net/ (NetBSD: free)
Anybody that knows about recent independent tests of PCB CAD?
Bolinder.
Bolinder.
Thanks everyone.
Once I've printed my boards out, would you suggest that I genuinely develop and etch them, or have any of you tried Press N' Peel?
I saw a few websites with really neat results on them using Press N' Peel, and it seems to save the effort of UV lamps, as I already have a HL-1450 laser printer.
The first board in question is a very small SMD switchmode converter. So, I will most likely produce a negative of the board to maximise the material left for conduction; only etching away the brakes.
