DPA-222 BJT amp from Upupa Epops
picture =/= schematic
but still very very very nice construktion, not only on a mechanical base 😎
Question to pavel, is it realy neccesary all the diodes for softclipping ? or is it just becouse the outpust stage is on an lower voltage then the vas and diff pair, would you still use them if all the devices or on the same railvoltage.
is this a commercial produkt or just for diy ?
I must little correct Per - Anders : it is pic of my amp DPA 222, which BJT, not MOSFET. This pic I was send him only as example of mechanical conception and, " mea culpa ", without name 🙂 . 386 have the same construction, only PCB is little bit short. All my amps have now the same mechanical / electronic design and I'm ready to explain it step by step and I mean, that you will be agree with me. Rudy ask me, if is neccessary to use antisaturation diodes and my answer is " yes " - when all amps will have this circuit solution, talking about " high gain or low gain " and " feedback or feedbackless " will ended. Guys, now is too late here in Europe, bed is calling, but if you will to can, I will write more tomorrow.
DPA 380
It is amplifier in which I was at the first use Cordell's error correction ( Per - Anders have scanned schematic from magazine, where I had published it, with measurig on Ap ). It was builded by maybe thousand people and still is, 'cos its parametres after twelve years don't lose excelent quality. In short : Output power - 130 / 8, 200 / 4. SNR - more than 124 dB ( IHF - A ), more than 120 dB linear. Fr. char. - 1 Hz - 300 KHz ( full power ). Distortion ( 1dB below full power ) 20 - 20 000 Hz below 0. 01 %. SR - more than 100 V / micro sec. Offset - below 1 mV. 2 Ohm stable. PCB's still available.
