double sided thermal tape?
Does anyone have experience with double sided thermal tape for mounting mosfets to a heatsink?
I found this product and not being an expert it looked promissing to me: "Ther-A-Grip™ 1050"
My project is a class A mosfet amplifier.
Thanks for any help.
I'd be worried about the logn term adhesive properties and resistance to vibration.
From the pdf.
Ther-A-Grip 1050 and 1070, when you need to attach a heat sink to an electrical package, consider Ther-A-Grip doublesided
tape.Ther-A-Grip 1050 uses a thin, Kapton MT-filled, polydimide film coated on both sides with pressure-sensitive, acrylic
adhesive loaded with aluminum oxide for good thermal performance and excellent electrical isolation.Ther-A-Grip 1070 consists
of a thin aluminum foil coated with aluminum oxide-filled, acrylic adhesive for electrical conductivity and enhanced thermal
conductivity.
http://www.chiptech.com/secondary/manu-prod_pdf/A/AAVID.pdf
Wow this Aavid Ther A Grip 1050 is very strong. I did a little test run with one device. It is tough to pull off after i stuck it on. I cleaned both surfaces with an alcohol wipe prior to sticking it on anodized aluminum.
Im going to use it on my Aleph 2 project, im convinced it will hold the driver boards.
