double DPDT switch?
What would be the benefit of running a simple switch+relay instead of a 4PDT switch? and how would you wire it?
I think Enzo already give the biggest benefit of a spst switch+relay.........being able to place it at the input rather than running cable to the front and then back.
It might be easier to get a 4PDT relay than a 4PDT switch that you like.
I can't think of another advantage off-hand.
On the disadvantage side is getting the right voltage for the relay. Perhaps current might be an issue. The space. Hum/click sound.
Lots of wiring guides available via Google.................
