Does this electrolytic capacitor need replacing?
Has the capacitor sat for years in storage? It would get warm during oxide layer reforming. That may have damaged it. You would always current limit when bringing up equipment that was in storage, or older NOS capacitors.
I'll assume the circuit wasn't drawing over normal or you would have mentioned the hum from the transformer. Without some specifics, it is hard to give you a good answer.
Reactions: Maserito
I am of the opinion that it is better to replace the capacitor. The capacitor is the smoothing capacitor of the power supply powering a boombox with detachable speakers. From what I learnt on this forum and similar forums, it is advisable to replace the capacitor. I estimate it is about 30 to 40 years old.
I asked to have a second opinion.
Thanks.
Hi Ed,
Okay, that really helps with situational awareness. Now we have a good idea of what you are dealing with.
Those are cheap, by all means replace it. Go for a replacement with the same lead spacing. Those cost more, and there is a good reason for it. Increasing the voltage rating is better than increasing capacitance.
