I am going to assemble a chain of modules on slots (smth like motherboard with modules) to condition subwoofer signal.
Does the order of modules matter? F.ex., due to construction matters I consider:
1. Buffer/summer of L+R chanel + Linkwitz transform
(both circuits sharing dual opamp, linkwitz transform needs a buffer)
2. Lowpass filter.
3. Phase shifter (elaborate schematics, requires dual opamp, has buffer)
4. Subsonic.
Eventually can switch 3 and 4. I want the phase shifter 3-rd or 4-th, so that the phase pot shares a dual digital pot whit the volime pot
(before the power amp stage). It will be easier pcb-wise if the digipot is closer to positions 3/4.
These are mostly construction/design considerations.
I assume, that the order we apply the signal conditioning does not really matter.
I only care if the input/output of each module has reasonable impedance.
And - the volume pot to be at the end of the chain for better signal to noise ratio (line level input for the whole chain)
Is that all ok
Kind Regards
2. Lowpass filter.
4. Subsonic.
Is that all ok
Kind Regards
