as far as i could conclude from the datasheet, it will convert from SPDIF to IIS only !
You can take an CS8420 instead !
grtz
Simon
grtz
Simon
If you use the circuit here
http://www.diyaudio.com/forums/showthread.php?threadid=21749
but invert it?
but invert it?
Using the above linked circuit will NOT convert SPDIF to IIS.
Spdif is a serial format with embedded clock and protocol information contained within the serial data. IIS is a different sort of 'serial' format. There are two clocks - BCK, a bit clock, to clock each bit of the signal in, LRCK, to determine if the data is left or right channel information, and DATA the data.
The data has no packet information, or error correction. It is pure music information data for both channels.
You will need a protocol adaptor. Look at AKM (Asahi Kasei) semiconductor, they make several types. A DIR is the input (SPDIF to IIS) transceiver, the DIT is the output (IIS to SPDIF) transceiver.
Hope this helps,
apollyon25
Hope this helps,
apollyon25
I2S to EIAJ circuit it what I need. DragonMaster has it right, but I don't know how to design a circuit or invert the one shown. I will need a schematic and parts list.
I think using the delay for DATA instead of LRCK will work.(In the scheme, exchange pins 2 and 3 at the input, and at the output the 3 different delayed WS will be DATA instead and DATA will be LRCK/WS)
I can't tell if it will work, try it or ask CM.
(BCK could have to be inverted . . .)
Oops, the link I told wasn't the same thing:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=25177&perpage=10&highlight=&pagenumber=3
I2S.ZIP
I2S.ZIP
I2S data is near enough MSB justified. The TDA1545A expects LSB justified data. Aside from inverting WS, FSYNC,WCLK, LRCLK or whatever name it goes by in your setup, you have to delay the data by 15 bitclock cycles.
My CD-PRO2M will output EIAJ, but it's default is I2S. I am also planning on installing a Crystal CS4328 dac for the balanced outputs. Can I configure the CS4328 to receive EIAJ? Then I will figure out how to force the CD-PRO2M to output EIAJ and run EIAJ to both dacs.
- Digital Source
- Does the CS8412 input I2S?
