Does solder quality have an adverse effect on sound?
Majority of diyAudio members seems to be from the 2%-world. Who know...?
Hey, A lot of people on the forum know about good design, as I stated. What percentage of them truly fall into this category? Not much. The people here know design for which I have great respect for. With sound or great sound, opinions are as many as the people in this forum......
Best of luck with your soldering to all..... Sometimes it's a pain for even a seasoned veteran! :nod:
Chris
Practice practice practice...Soldering is a learned art. You will find it's better to take your time. Let the iron do the work. Rule 1, the solder is your heat bridge, let it work for you. You will learn this quick when a dry iron won't solder squat. Clean your iron ( I prefer a good wire mesh pad versus a wet sponge that will lower your tip temperature just when you're ready to solder) "Tin" your iron tip and use a good quality solder. I use Kester "44" rosin core solder (63/37). It helps to also tin (presolder) you parts; wire, leads... and remember " the bigger the blob, the better the job" is NOT TRUE. I remember going through NASA certification and you want to talk about "anal". This is to much, that's not enought, that's just right, and even with a microscope. Wait till you get to hot air then the fun really starts. Bottom line, take your time and it will save you headaches down the road. Now have fun, after all this is a hobby. 🙂
Good post.... I will agree and disagree with you at the same time. Mostly, "the bigger the blob...." Try repairing pro audio, especially guitar amps and keyboards. The jacks and filter caps need big blobs!!!😉 Most of the POTs as well!!!!
So, ya done any BGA rework? Now that's fun. I like working under a microscope too but those jobs dried up a couple years ago.:bawling:
OH WELL!
Chris
The best solder to use is the one you find easiest to work with because that's the one that will give the best joints. A while back I was concerned about some delicate ICs that I tried a Kester specialty solder #58/245 that has a very low melt point. I've gotten in the habbit of using it for general use because it is so quick for both soldering and de-soldering that it compensates for fading near vision and shaky hands. (Us old geezers have to put up with a lot!)
A great way to get better without hurting any projects is to use a solder practice kit. You can do a search for "solder practice kit" and find lots online. The one below I did as part of a certification class. It is from Omni.
IF you are new to soldering, just get SN62 or SN63 from a quality manufacturer. Don't waste your time, at this point, with anything else. Trust me, I built my first Heathkit in 1959. Some kits that I built, even then, still work, but they look pretty bad, inside. SN62-63 will keep you from cold joints and both are low temperature solders. Flux quality(inside the solder) is important! Don't cheap out with RS. Get a name brand.
