So do these three parameters explain a drivers abilities?
I mean can you tell a good driver just by looking at these three parameters, or at least get a good idea of a driver?
Consider the following drivers;
Driver1 6"
Qms 5.56
Qes 0.49
Qts 0.45
Driver2 7"
Qms 1.77
Qes 0.46
Qts 0.36
Driver3 7"
Qms 7.00
Qes 0.38
Qts 0.36
Driver4 6.5"
Qms 3.47
Qes 1.15
Qts 0.86
Now just considering these parameters can you get an idea of which would be better or which would be worse? Some have high mechanical Q, some have high Electrical Q....does it make a difference?
Now to see how well you guessed, I'll devulge the names of the drivers. I'm not trying to say anyone brand is better than the other I just tried to find different examples from different price points.
Driver1 = (HiVi M6N) $45
Driver2 = (Vifa XG18WH00-08) $93
Driver3 = (Focal 7W4411) $151
Driver4 = (Goldwood) $17
Just wanted to include a wide range of prices and specs.
I know this will probably spark some debate. I know these must mean something. Someone on here once said that Tang Bands were not good drivers because they were not physically made to the same standards that traditional European drivers are, yet those numbers don't seem to reflect that. If anything Focal has horrendous Qms values when compared to their prices, while Scan Speak long known as a "great" brand has high prices, but values that are more in line with everyone else.
Driver1 6"
Qms 5.56
Qes 0.49
Qts 0.45
Driver2 7"
Qms 1.77
Qes 0.46
Qts 0.36
Driver3 7"
Qms 7.00
Qes 0.38
Qts 0.36
Driver4 6.5"
Qms 3.47
Qes 1.15
Qts 0.86
You skipped to the second question without asking the first- how do you define "good"? A driver which is fine for design A may be lousy for design B.
I think it depends more on how honest the company is when they quote their specs. They can put anything they want. Perhaps if the TB drivers aren't made to the same quality, its not that the overall parameters are worse or better, but the drivers may not come out the same off the production line... Ie. greater variance in production.
Pete
Pete
Hybrid fourdoor said:So do these three parameters explain a drivers abilities?
If anything you are paying for the high Qms in the Focal.
Seems to me you don't understand what Qms is.
Qts is the result of both Qe and Qms.
Qms tells you something........ but hardly the total picture.
🙂 sreten.
Just keep in mind these figures will give you a prediction in physical behaviour of the drivers, but NO information about sound quality. It's comparable to distortion figures in amplifiers: high feedback gives nice figures but sound dull.
A correct tuned enclosure is only a beginning...
Nope. If you have Qts, Fs and Vas, you are closer. With these three parameters you can evaluate if you can design the frequency response you want, and what box volume you need.
On top of that, there are a *bunch* of other parameters that will determine the end quality of your system, like Xmax, Power handling capacity, cone breakups etc.
Qts=Qes*Qms/(Qes+Qms), and it is only Qts that is important. Well, almost.
of course there are other parameters (just ask hunter audio) but i think the question here is how far do Qes and Qms go to explain the driver. i dont know where i read this but somewhere in te back of my head a little voice tells me to keep Qms under 5 and Qes under 1 (preferably under 0.7).
i cant remember where this recomendation was posted or typed.
Well, almost.
That's it. If you want to have low mechanical losses (i.e. a high Qms) you have to make some efforts (low friction or airflow resistance, Kapton formers instead of Aluminium...). There are people saying that drivers with the same Qts but larger Qms would give more accurate bass reproduction (often cited by the two German DIY speaker mags).
Charles
Charles
Why would low mechanical losses be important? Are they worse than electrical?
they are not worse but mostly related to the fact that efficiency is traded for a more flat response. In most cases suspension stiffness and freq-response-behaviour is chosen to modify or smooth out some peaks in overall freq-response.
This can cause a 'foggy' ie. less grainy response.
That's the main reason I personally tend to prefer pro-drivers.
Frequency-response smoothed-out electronically by means of a dsp is far better than damping the whole speaker response.
Qts, Fs, Vas predict the driver's bass response curve in a box of various types-or even on a dipole. That is it.
Even then, sensitivity, linear excursion, power handling, all come into it.
Generally, these numbers are less critical in drivers that are to be used in midbass or midrange applications. And has been pointed out, these numbers tell you nothing of smoothness through the midbass and midrange regions, which is what most consider important.
lieven said:Why would low mechanical losses be important? Are they worse than electrical?
This makes no sense to me. Qts describes the height of the peak at *fs* when driven with a voltage source. Qms is the same but without the electrical damping, ie driven with a current source. So the Qms is related to the mechanical losses when the cone moves back and forth.
Now, let's assume for a moment (and I am not very happy about it) that these mechanical losses also have an effect on other resonances in the mechanical system, for example a cone breakup. Wouldn't a *high* loss be desirable then? A high loss would bring down the Q of the breakup and the "peakedness" would be smaller. Assuming that the Qms resistance has anything to do with cone breakup at all...
hi
a driver cannot be defined by ,
to consider its t/s parameters , never actually suggests how it will play
or the materials it may be constructed with , ofcourse if it was to be used by the police force - kevlar is very important
but when it is to ultimately convert source to analougus sound , what are on line is its realism , accuracy , depth , tone / timbre , nature etc in hi fi
in pro audio - directivity , effective spl , accuracy , decay etc
it cannot be defined by a mechanical formula
what has all this got to do with diy ?
when one has to choose a drive unit or units for ones amp / speaker enclosure in mind etc
what are the factors worth considering ?
considering a purchase of a loudspeaker unit
ts parameters defines this unit mechanically , through these mechanical parameters one can proceed to use / utilise the unit to its best , including efficiency , and is of utmost importance to its enclosure design enclosure
but one has also paid for the materials used in the construction of the drive unit ,
this will decide its longetivity , compression at peak power , overall accuracy - not to mention the tonal quality or the nature of sound produced
where am i heading , - the internal volume of a cone may be same as that made of ordinary hard pressed paper or for eg a kevlar woofer
1 set of compliance figures can be easily duplicated between
a rubber surround cone / and a foam surround cone
all the manufacturer needs to do is control the hardness factor of the rubber surround material (ie the rubber)
and
the density of the foam material _ of the foam surround
with this surround material differance the sound quality of both the drive units will be entirely different
- along with the materials used the construction process is of importance
so is the x- max the voice coil inductance , the cooling efficiency
distortion - can be reduced by a symmetrical field magnet structure , shorting rings for eddys , shorting rings built into the coil to limit the coil from leaving the magnetic gap during extreme excursions
these important issues relating the drive unit is not reflected very much in the t/s matters
where am i going ?
i can copy a standard 100 $s subwoofer unit' s t/s parameter using
ordinary components for eg a pressed paper instead of a non press one , same coil dia , wire winding etc but with a poor insulation
and it will never play , last , sound as the original 100 $ s one
this is of utmost importance to diy constructors , along with t/s parameters
Reverting to important issues governing diy and speaker design
1 . The speaker matching with the amplifier ,
I can provide a double magnet (155 to 230 mm) subwoofer in a lambada extended pole underhung sfg topology magnet structure with a kapton voice coil with imported aluminum wire voice coil lengths in excess of 60 mm with a xmax of 25 mm at 4 ohms , a imported non-press paper rubber surround cone (which totally absorbs all mid + hi frequency due to the cone design)
and
if the user constructs the most powerful IC amp it will not match
infact it won’t match a 150 w rms transistorized design using latest Toshiba ets transistors
the reason – the magnet structure is over damped
now if it was the crescendo mosfet amp then we are going somewhere ,
Two
the type of the transducer , its power handling , has the voice coil size been increased blindly to increase power handling without magnetic efficiency and x – max in mind ?
the type of cone used , pressed paper , semi press paper , non press paper , felted composite , reinforced ets ( this decides how the speaker will sound )
the motor structure , sfg (symmetrical field geometry magnet structure) , for full range and pro drivers if there are eddy current shorting rings , other shorting rings employed to extend frequency response , linearise impedance , improve transience
the vc material and wire , the vc inductance – 2 layer , 4 layer , dual vc type etc
the suspension system and compliance
surround material , eg rubber then type natural or synthetic ets , the extent of the roll of the surround and its match with the spiders
the construction – at the end all parts of a speaker is held together by adhesives , the quality of adhesives used / and the process of manufacturing , for eg if I repair a toy with a epoxy hardener type adhesive and do not allow for the correct drying time …
at the end all manufacturers are increasing production speeds
suranjan
transducer design engineer
and
where am i going ?
and
Two
suranjan
then a good driver ?
hi
this statement can be said as correct that :
a power rating given to a driver , means that at all input levels of the driver rating within its specified limit , the driver :
1 ) should perform within the rating in long term use , robustness
2) should perform within very acceptable limits of distortion
3) and should show a certain limit of linearity in relation with the , actual accoustic power output increase to the input power supplied from the amps
without compression
the distortion is now adays mostly the deciding factor of the power rating including long term use
Here it needs to be devided in two sections
FIRST SECTION
in a broad context
distortion / you will find some speakers distorting _ much before the voice coil actually burns out
for eg - considering a driver in which this takes place :
a driver or if they are pro audio or drivers with simple pole vent cooling with the coils set in a tight magnetic gap - the coil can be on a paper former , oridinary wires used in the vc s
the vc s temperature will not rise easily normally 60 deg max , at this time it will distort
then this distortion is not from the vc temperature
(though in most books vc temp is one of the main source of distortion , why ? read on ....)
there are 3 basic types of non linearity in a transducer , these generate distortion , due to this distortion the voice coil heats up / at this moment no amount of cooling can help ,
the distortion effect from driver non linearities are such that it may lead to vc temp rise exponentially leading to vc burn out
the non linearities are
1. non linearity in the suspension mechanism
2. non linearity in the motor sturucture
3. non linearity caused when a coil moves in a permanent magnet motor structure (this is bound to happen even if the above 2 non linearities are addressed well )
to check for these non linearities while purchasing drivers
1. suspension non linearity
for the x - max of the driver you would like to purchase (or the one specified by the manufacturer) meaning you either know the x-max or have one in mind , then :
step a
push the driver cone downwards by that amount , it should go down linearly (the stiffness of the suspension increasing linearly) to the amount of the x-max
step b
pull the cone upwards towards you from beneath and it should come up to the specified x-max , again stiffness increasing linearly
if this does not take place the driver will distort -
unless the transducer manufacturer identifies specifically that such a non - linearity has been addressed , by making suitable compensations in the vc itself
2. motorstructure non linearity
fringe fields exists at the magnetic gap - the motor structure should be - sfg a symmetrical field geometry _ topology
therefore while purchasing a driver look if the motorstructure is - sfg or not
since expenses goes up in a sfg structure it will be specifically mentioned mentioned by the driver manufacturer , to inform customers
3. Non linearity caused when a coil moves in a permanent magnet motor structure
explaining this nature of non linearity is complex , anyone interested can see the sections on shorting rings in my thread
what is important
is that : -
has this been addressed by the transducer manufacturer
it is addressed by shorting rings placed in the motorstructure
since this too involves expence , and a considerable slow down in the manufacturing process this too will be specified by the driver manufacturer , to inform customers
the above are the main sources of distortion that determines the safe operating power of a driver , and are not the only sources of driver distortion (other sources of distortion are eddys , bottoming to name a few)
due to such complex stuff good driver manufacturers all over the world can be counted on finger tips
SECOND SECTION
in good drivers context
good drivers are in which all the above criterias have been addressed
then the rise in vc temperature over long time use / the cooling efficiency comes in , and mostly all speaker failures of reputated manufacturers result from vc burn out (as mentioned by Navin)
mostly these limits are tested thoroughly and drivers tested to distruction and safe regions specified
i have found driver malfunction due to negligence of owners to go in for a service contract when pro audio drivers are used eg - movie halls , discs
in home audio , sources of reputated driver burn outs are :
a)
amp malfunction and dc component generation in the drive signal or signal clipping
speacially when high power speakers are used by under powered amps , many people do not even consider that a 35 w amp can damage a 100 w speaker system _ plain simple signal clipping can distroy well made drivers
if you have an under powered amp please ask a sound engineer to determine the clipping levels of your amp and restrict from running at clipping levels (in high end audio amps from manufacturers like Nad and onwards this is built in as standard , in the circuitry , therefore the prices)
b)
or the suspension parts have outlived _ may be the owner !
thanks navin for the reccmn.
Suranjan Das Gupta
Transducer design engineer
hi
without compression
FIRST SECTION
in a broad context
step a
step b
what is important
is that : -
SECOND SECTION
a)
b)
Suranjan Das Gupta
the simple answer here is Qe is a predictable parameter
and a consequence of the magnetic and electrical parameters.
Qms is not. It cannot be treated as a lumped parameter.
It is the mechanical damping of the system and as such
reflects the way the drive unit is made and its subsequent
behaviour.
Consider a driver with low Qms. Is this due to the cone surround
or the voice coil spider ? It should be obvious that the point of
application affects unit behaviour.
Another point is is Qms entirely resistive ? What is certain is that
cheap drivers with low Qms (allowing savings on magnet induced
Qe damping) are certainly not, the type of damping applied
exhibits hysteresis, that is it is non-linear.
Of course simply measuring Qms will not indicate this hysteresis.
and where is this hysteresis applied ? at the centre or edge ?
By implication a driver with high Qms will be less likely to suffer
from hysteresis type effects.
I believe it is generally accepted a driver with a low Qms due
to the surround (for optimum midrange termination) does not
make a good bass driver.
And when used as a bass/mid there is a bass quality versus
midrange quality trade off, you could argue that a high Qms
driver must have compromised midrange.
Note that hysteresis effects of the surround are negligible at
midrange frequencies / excursions, it acts more as a damped
cone edge terminator.
🙂 sreten.
behaviour.
🙂 sreten.
So, sreten, you are basically saying that a high Qms is desirable, because this means that the mechanical losses are low, and that low mechanical losses is good since they mostly are nonlinear and hysterical (or whatever the adjective should be 😉 )
Did I get you right?
car comparision
let's pretent a car with a certain weight.
It has a certain spring/dampening optimum related to it's weight.
You can choose stiffer springs or harder dampers, each combination will give you another 'character'.
For racing you choose stif springs/ relatively hard dampers, for off road racing weak springs/ soft dampers. Why? I recon you see why.
Fact is that in off road racing dampers have to dissipate a lot of energy because they have to absorb the long excursions of the suspension. But they enhance driveability.
On the other hand off road suspension don't give that much information to the driver's steering wheel. There's a loss of information because suspension in absorbing alot of that info.
In circuit racing it's more important that the driver feels the exact moment when tires are loosing grip, so suspension has to be more 'direct'.
Note that an off-road suspension is usefull even on circuit, not optimal, but useable, but circuit-suspension is unuseable off-road.
Re: car comparision
OK, completing the analogy with loudspeakers, this tells me that Cms and Fs is important (which is set by the suspension stiffness and the mass of the car) but also that the *Qts* is important (which is set by the shock absorbers (is that the english word?))
There is no Qes in the car analogy, so Qts and Qms are the same, so we cannot draw this parallel too far.
lieven said:let's pretent a car with a certain weight.
not physically comparable with the Qes, because Qm and Qes work in paralel (Qts= (Qm*Qe)/(Qm+Qe)), but in cars you have also the undamped weight namely the tyres (including brakes) wich are also a system on its own with different tyres characteristics and inflation pressure. This system is in series with the suspension so for cars it is Qsusp+Qtyres=Qsystem.
The problem is the same, more specific tuning cause less overall useability.
The solution is also the same: dsp-processing wich alters the Q - characteristics along the way.
lieven said:not physically comparable with the Qes, because Qm and Qes work in paralel (Qts= (Qm*Qe)/(Qm+Qe)), but in cars you have also the undamped weight namely the tyres (including brakes) wich are also a system on its own with different tyres characteristics and inflation pressure. This system is in series with the suspension so for cars it is Qsusp+Qtyres=Qsystem.
Well, the tyres also have a mass, so the analogy does not hold in detail, really. My point was that in speakers damping is damping, regardless if it comes from Qes or Qms. sreten had a point about the mechanical damping being more non-linear, which may be true. Otherwise I see little difference between the two.
- Does Qms, Qes, and Qts explain a driver?
