Does my power supply really need 140A?
First of all I've been searching for hours on the internet (forums like these are usually a last resort for me because I know I'm just another dumb noob asking a question)
Anyways, I'm setting up my car amp/sub in my house and I'm trying to find a power source for it. I've already ruled out bringing a car battery in my house.
I have two options: Make a power converter myself or buy one. I've made small level stuff before but nothing like this. Either way I need to know...
My amp (MB Quart Onyx 1500.1, specifically 1000W RMS @ 2 ohm) uses two 70A fuses. Does this mean that it draws 140A current? I can't imagine that this is true because that's a lot, but I can't find any logic to disprove it. The subwoofer I'm choosing to run is 750W RMS @ 2 ohm.
Basically I need to know much much amperage my power source would need to be capable of having.
Thanks in advance for all of the help.
Well, let's make some general assumptions.
If you have a class D amp at 750W output running at 85% efficiency then you need 882W of power for your amp. ( 750 / 0.85 )
If you have a DC-DC converter to produce the supply for the amp running at 85% efficiency then you need 1038W supplied to that DC-DC converter. ( 882 / 0.85 )
At 12V that would work out to be 86.5A. ( 1038W / 12V )
You can change the efficiency numbers and the 12V supply to match your needs but that is how you can get a reasonable idea that you need a lot of power to make a lot of power.
Hope that helps.
(If the amplifier is not a class D then the efficiency number would be lower. Class AB <70%.)
Numbers alone don't mean much, so don;t look at numbers and ignore the context. 70 amps may SEEM like a lot of current, but your system runs on only 12 volts. If it ran on 120 volts, the same amount of power would only need 7 amps.
