Does anyone use the modern PCI-E - i2s solution on a PC?
I tried to find out about available multichannel PCI-e-I2S bridges a few months ago. I could find the only multichannel PCI-e chip publicly available (not custom like Creative XFi etc.) is from CMedia CM8888 which AFAIK is used e.g. in https://www.pinkfaun.com/shop/bridge/69-6445-pink-faun-i2s-bridge.htm . I asked CMedia and was told that chip is End of Life, not available from the manufacturer anymore. Even if bought from some seller, it requires a firmware for which CMedia does not want to release docs.
IMO that's one of the reasons why e.g. https://www.evga.com/articles/archive/01281/evga-nu-audio/default.asp is USB-based, using PCI-e USB xHCI host chip -> UAC2 receiver -> I2S codecs (with another advantage of not having to write custom drivers for xHCI -> UAC2 🙂 )
A number of PCI-e soundcards use legacy PCI-I2S chips with PCI-e <-> PCI bridges onboard, e.g. ESI Juli@ XT etc.
An FPGA could be programmed for this task, but FPGAs with PCI-e support are quite expensive.
I haven't been interested in sound cards for a long time and didn't even know there was a PCI-e version of Juli@ 🙂
I need only stereo, perhaps it is worth considering of trying to get i2s from a similar board? 325Euro for finished PCI-e bridge device looks a little bit expencive for experiments
As far as i know, my Xonar D2X, which is a PCI-E card, uses the PEX8112 bridge-chip, to run the CM6631/ Asus AV200 PCI chip.
I managed to get some chips from an old card, but i have no idea if they survived the procedure ... .
All the good Xonars (D2X, ST, STX I & II) are used not really expensive. Maybe these could be a source for chips?
Those chips are PCI/I2S interfaces, similar to e.g. Envy24/ICE1724. E.g. CM8888DHT are still available. But the chips require a firmware to customize, there is no register-level documentation available, and C-Media will not provide it because the chips are EOL (I asked them specifically). Author of the linux alsa driver https://github.com/torvalds/linux/blob/master/sound/pci/oxygen/oxygen.c likely had some access to the docs, but likely under NDA (you could ask him).
ICE1724 chips would be more interesting as they have full docs available, but unobtainium anymore.
