Something to do with China and USA legal Mumbo-Jumbo... Maybe just US attorney's can't speak chinese???
The erased part is hardly "diyzone" and the rest is www.????.comPeter Daniel said:If you look closely at the pictures, there is a web address printed on the boards, however somewhat erased.
It's worth noticing that the RIFA's are mounted up side down. The datasheet says up or laying. But this has maybe to do with the safety valve.
The Rifa's turn the wrong way on those pic's indeed. If something goes wrong, you will have bad smelling Electrolytic fluids running out!! On another note, now that we are at it anyways, I heard persisting roumors about fake Rifa's from China😱 Why not, they copy everything!!It's worth noticing that the RIFA's are mounted up side down. The datasheet says up or laying. But this has maybe to do with the safety valve.
Steen.
They probably aren't real Rifas anyway. If you're going to be counterfieting, may as well go all the way.
The problem with ripping of any part is that you can not be trusted on anything else.
