I've been wanting a pair of Tang Bang W8-1772s but my cost delivered in Au is $700. so I was looking in China where TBs are made and found these Aucharm WHFS-AU-P810s for nearly $300. less. A search on the model number found nothing. I trust I can get an opinion from the Full Ranger crowd.
-thanks, Mack
94db, 50Hz -20KHz, Power 18W – 36W, Cast Aluminum
HIFI 8 inch Full Rang Frequency Speaker Unit High Sensitivity 94Db 8 Ohms 50Hz 20KHz Whole Cast Aluminum Frame DIY Audio-in Speakers from Consumer Electronics on Aliexpress.com | Alibaba Group
'gotta appreciate the seller's honesty:
"If you like to listen to heavy metal or hoarse magnificent large dynamic symphony, then you can turn off the page, and I'm sorry, this speaker really cannot withstand such a torment."
1. Impedance: 8 ohms
2. Size: 8 inches
3. Frequency response: 50Hz – 20K Hz
4. S.P.L.: 94dB/W(m)
5. Power rang: 18W – 36W
6. Net weight: 2350g
7. Mms: 5.056 g
8. Mmd: 3.477m Kg
9. Kxm: 1.080 H
10. Vas: 107.980m M
11. Cms: 1.978m M/N
12. Krm: 172.702m Ohm
13. Erm” 0.295
14. BL: 3.719 T/m
15. Qms: 2.988
16. Qes: 0.832
17. Qts: 0.651
18. No: 1.599 %
19. Revc: 7.200 Ohm
20. Fo: 50.329 Hz
21. Sd: 19.607m
-thanks, Mack
2. Size: 8 inches
7. Mms: 5.056 g
8. Mmd: 3.477m Kg
9. Kxm: 1.080 H
10. Vas: 107.980m M
11. Cms: 1.978m M/N
13. Erm” 0.295
14. BL: 3.719 T/m
15. Qms: 2.988
16. Qes: 0.832
17. Qts: 0.651
18. No: 1.599 %
19. Revc: 7.200 Ohm
20. Fo: 50.329 Hz
21. Sd: 19.607m
it looks like a hybrid of the old ferrite magnet L. Cao 20cm speaker and something from Guide-Sound mms isn't right in the specs above
Feastrex full range speakers
For that sort of money, I would expect at least 101dB and not pay for the shiny, worthless, gold plated solder terminals.
Looks like an average speaker that is disguised as a proper one to me.
Take away the glitz and this is what you have; http://cpc.farnell.com/unbranded/fc682637/speaker-2-way-full-range-40w-8/dp/LSL200WTC
I'm lucky (one of the few times, as I also have trouble sourcing good drivers) to live near the head office of TB.
I emailed them and got myself a pair of W8-1772 directly from them. It is a great driver, but it is not an easy driver. It takes a lot of love to make it shine.
In my quest for finding good drivers for another project, I got a pair of Aucharm (the little 3incher you see advertised on that same page you linked).
That Aucharm is the worst of all the drivers I got so far... distortion is just unbearable.
I'm not saying this 8" driver is the same, but for that amount of money... I would make sure I get my money's worth. Because if it performs way below your expectations, that's money you will not see again.
Take away the glitz and this is what you have; FC682637 - UNBRANDED - SPEAKER, 2-WAY FULL RANGE 40W 8" | CPC UK
Blimey, they've sold these for an absolute age, I bought a set of them over 10 years ago.
101dB would be substantially louder than the most powerful (much more expensive) neo magnet Lowther, which is 98dB 'raw' and <95dB after eq.
Preliminary Measurements of the Lowther DX Series of Drivers
94dB is actually very high efficiency for a high Qts driver, which presumably wouldn't need the same eq.
101dB direct radiators are only slightly more common than unicorns.
Other options that seem good for Aust (low delivery)
Visaton have an Australian distributor and a couple of FR drivers
Diatone clones
Any FAST that uses a locally available bass driver
P-Audio coaxials
Diatone clones
P-Audio coaxials
if that Diatone cone/ whizzer hybrid is as good as the little L. Cao F6 6.5" driver then it could be pretty nice
here's the F6 in a Karlsonator prototype vs an Eminence Delta Pro-8a rated 97.6dB
are you serious? where did you find the similarities?
What's wrong with it? Loading Mms, Cms, etc., specs into WinISD 0.7, it calculates everything the same as published except for Vas, which is only fractionally off at 107.87 L.
Anyway, assuming the specs and frequency response are accurate enough [big if], then except for a fragile diaphragm and having maybe 1 mm of 'safe' travel, limiting the LF to < 1 W unless there's some room boundary loading and/or driven with a high output impedance, it seems fine if a bit pricey. $300+/ea. just to get it to the USA would have me looking at a two way.
GM
I seriously doubt it unless Aucharm's specs, pics are pure fiction.
GM
I was very pleasantly surprised quite recently by a pair of diy OB speakers running L Cao 8 inch full range drivers in my living room during a recent get together. First FR I have liked short of the TB W8-1772/1808 drivers. I have heard a few horrible FRs and tend to run the other way when encountered.
These ones specifically: http://www.onecaudio.com/lcao_eng.html
hey GM, I just thought mms of 5.056 grams was awfully low for an 8 inch driver A Nirvana Super 8 cast frame has mms 11.748g and they aren't very heavy mass wise
It is, near like tissue paper, and no doubt why he cautions even touching it, so a pristine make-up brush seems the only way to clean it if true.
GM
GM
tilroh
i think mms 15 g could be real,
if i see the data,
look better for the money a better driver
H1597-08 FA22RCZ
if i see the data,
H1597-08 FA22RCZ
I've played with my fair share of unknown Chinese full range drivers, and they
have ranged from ok to good. None spectacular, none bad, all worth the
price and fairly represented.
if i see the data,
H1597-08 FA22RCZ
They are interesting. Good price. FR plot looks like a Lowther, but a bit flatter, the highs only about 10dB hotter on axis. 6mm Xmax is a lot, for a driver of this type. I like that the power handling is not a stupidly hyped number 🙂
For efficiency:
The specs state 94dB sensitivity, but the FR plot shows that's only true at about 1kHz. Putting the Fs, VAS and Qes into a calculator, I get 91.6 as the 'real' efficiency. The Madisound listing for the driver shows that, with passive eq, and with support under 200Hz (most likely from a back loaded horn or additional woofer), the resulting system would give about 89dB per watt.
Joined 2009
The FR plot on that Seas looks terribly ragged at the top-end.
The FR plot on the L.Cao is not 'native' but after EQ is applied.
- Full Range
- do these Chinese 8"full range look familiar?
