Do hard coat anodized aluminum heat sinks require non conductive grease or pad between chip and heatsink
What conductive grease? Heatsink "grease" is not electrically conductive. It is a great electrical insulator as indicated on the attached data sheet at 5 x 10-14th ohms per cm, and a great thermal conductor at the same time.
Some of it is very conductive. Made that mistake once.
If I were going to rely on anodizing for insulation I would use some scotch brite on the parts to make sure there are no sharp edges. Aren't there some manufacturers known for only relying on the anodize?
