DMM with Nanoamp Current Resolution
I was going to say (and should have), you will most likely require a calibration dmm. To read nanoamps requires a balanced input, which the 8808a has. If you notice they mention 2/4 wire, 2 wire is common of all dmm's but 4 wire is balanced, nulls common mode noise which is the kicker. Currents of this magnitude can be easily influenced by just about anything, including your proximity. Any king of stray capacitance/inductance from the leads, emi etc. Best if used in a screen room, think faraday cage. Do not know any individual that has one. Well a friend does have one built to protect his backup computer and data incase of a emp bomb, but thats a subject for another day 😀
To read nanoamps requires a balanced input, which the 8808A has. If you notice they mention 2/4 wire, 2 wire is common of all DMM's but 4 wire is balanced, nulls common mode noise which is the kicker.
Ahem... 4 wire (Kelvin sense) techniques are for measuring low resistance values and have nothing to do with the problems encountered when measuring low currents. Low currents may require a guard terminal (the 8808A doesn't have one), but at 100 nA that's not an issue (unless you ask for ppm uncertainties). What the 8808A *does* have, and it's unusual for its class, is a IV-converter based current measurement. That offers very low voltage burden which is advantageous in some application (possibly also in the one under discussion).
Measuring base/collector curreents is not a task that requires very low uncertainties. hFE varies about with 1%/°C, and the collector current is usually quite temperature dependent as well (e.g. intentionally "proportional to absolute temperature" (PTAT) for precision opamps). All we want to do is distinguish 150 nA from 180 nA, and not affect the circuit operating conditions too much. No metrology certificate needed. 😉
Samuel
I took a look at a Canadian Fluke site and couldn't find any of those numbers. There was, however, a desktop multimeter that looks like it should fill my needs and some, the 8808A.
My advice would be aim only for the 8050A which is 20.000 counts.
Try a Keithley 2001.
Range Resolution
200 uA 10 pA
2 mA 100 pA
20 mA 1 nA
200 mA 10 nA
2 A 100 nA
Maybe a Keithley 2000 will be ok also?
The Keithley 2001 is $4000-$5000 new, and even used, they go for over $1500 in good condition. That is the price you pay for 7.5 digits, and it is not something most hobbyists need to have on their bench.
Range Resolution
200 uA 10 pA
2 mA 100 pA
20 mA 1 nA
200 mA 10 nA
2 A 100 nA
The Keithley is just a fancy op-amp with an electrometer tube input you can read the manual. It has a "fast" and "slow" mode one of which is a transimpedance amp using virtual ground this essential for measuring junction leakage where NO voltage burden is essential.
You can but several op-amps with 20fA input current and one I think at 3fA and use a big feedback resistor. You could also synthesize a big resistor with a T feedback network. The Keithely gets around 10 atto-amps or so. If you just want 10nA or 100nA full scale a chain of 1 or 10 10Meg resistors would give you a volt full scale.
If the shunt resistor approach is necessary floating everything on batteries will work, some Keithley's used mass quantities of batteries including one of those 90v B+ batteries from old radios.
I am working on guitar effect boxes and would like a DMM that has resolution to the nanoamp for measuring base and collector current being fed to transistors. I am often finding current values in the 100 to 200 nanoamp range and need to be able to evaluate them to something finer than .1 microamp in order to determine proper gain values. Would prefer something not out of hobbyist's price range. Bench or hand held is not an important factor.
If anyone knows of any particular meters that would fit this bill or can point me to source material your help is greatly appreciated.
Lots of very good, Lab quality suggestions.
Fine, didn't expect less.
Most seem to have skipped the:
for God's sake 🙄
Well, although technically correct, you don't actually need
but you might apply an obscure and often forgotten piece of knowledge called by ancient alchemists the Ohm's Law.
I think you are designing simple transistor gain stages and want to bias them properly.
In that case, get a Protoboard, a 9V battery, and a 10M resistor (I doubt you will use biasing resistors higher than that, if anything because they become somewhat harder to get and simple flux residues on the PCB, in a humid day, will cause you problems).
Conect emitter to ground, base to +9V through the 10M resistor and measure current flowing from +9V to collector, which I'm certain is within your Multimeter's capabilities.
Hfe or current gain will be Ic/Ib where Ib is 8.4V/10M=840nA
Do you want to measure it at 10X lower currents?
Use a 100M base resistor, although at such impedances and currents, leaks and losses will dominate the field.
Even if physically possible, I would not design such a pedal which would be difficult to produce and easy to drift and fail.
Just curious, can you post the schematic (or the relevant part) you are trying to design?
Because Keithley is a hollow branding this days and part of DANAHER group, most of their recent products is re-branded meters from Taiwan.
A bit of extra research could lead you getting what you like in a friendlier price.
Probably best to consider the ones on ebay. You could even buy one for parts only and substitute a modern electrometer op-amp. I expect this would work down to the pA level.
Me, I have my trusty 610C for going on 35+yrs.
for God's sake 🙄
Essentially this is what I advised a few posts back. Using the handheld DMMs built-in hfe tester does exactly the same.
I am actually in the midst of working through a number of pedal designs and mods and have determined, for the amount of time it takes, it would simplify moving transistors in and out of designs with a little foreknowledge of what to expect of the transistor under operational conditons, it is not about determining the bias point as much as determining how big a punch any one transistor is going to supply. Hit or miss trial and error, in my estimate, is a waste of time that could be put to use elsewhere. I am accumulating and hope to catalogue the gains on a number of transistors and then, knowing the enemy, work from there. There is a lot of different information out there. Everything from real world to incredibly over the top hype. I believe I'm better served if I just find out some of the answers for myself.
Which model are you referring to? The 2001 mentioned above doesn't go to electrometer territory.
Samuel
