Good morning
Someone could send me pictures of the module without 1KW1CH integrated welded?
I need the links between the two chips
many thanks
many thanks
Hi Pergo, Did you able create your own modulator board? in replace of DLM4000? thanks! I badly need this for myself.
Hello!
Anyone could give the pin out function of a DLM4000? I have a 6kwatts Firland mono amplifier but it produces distortion on the upper side of the sinewave.
Thank u.
Thank u.
Good evening Pedro, if you have found a replacement module for the DLM4000A or know of where a replacement could be purchased, could you share it with me, my vested build is in need of one possibly two as a back up.
I have two Soundstream Tarantula xxx 10000D car audio amps and the module in one went bad.
