diyAudio "Wolverine Pre-order"
Thanks for setting this up, JT.
First, Pete I hope you're well up in NY.
This may benefit others for the pre-order, so I'm putting my question here vs. the main thread. I read through the entire Wolverine thread, and I am certainly interested when/if any additional IPS become available. Did I understand correctly that the "standard" IPS section on the version of boards for preorder can be populated and then (potentially at some later time) a new IPS can be installed even with the parts populated by moving a jumper header and/or a small solder job? I believe I read that correctly, but I am not sure where the team landed re: "full modular" with separate IPS boards or the all in one solution. I know the original proto boards that were posted in the main thread were "single boards". What is the plan for the store? What boards are being offered for pre-order?
I also know that the amp is still technically in development, but is there an opportunity to review a draft build guide? That may let people know what they're signing up for.
Me... I'm in either way!
Patrick
