DIY ...worth it?
This was one fellows DIY design, it grew into a group design/build.
Crazy low bass, they just sound fantastic in the HT. Also have one in a 2.1
cost? $8 woofers ($32 total) - wood $25 - white fill $5
Very cool design- got a link? Also, the woofer section should be braced from mounting to mounting- this sub could take advantage of force cancellation.
In the end, displacement volume is the key to low and loud base. And the 10" Dayton woofer got +-14mm of linear excursion. With a surface area of 350cm² x 2 subs you can move a lot of air (as much as with one good 15" woofer or with two casual 12" ones).
I recommend seal boxes, because they don't release as much energy into the room as a 20hz ported design would do. Therefor your room is excited less (room modes again) and the bass sounds way clearer.
And consider, your small room won't allow you to produce any frequencies below ~25hz. So don't waste money and acoustic energy by trying to build a 25hz subwoofer. 30hz is all you need, trust me (and you can still add a few hertz by equalizing the sub)
I think dual subwoofer are a waste of possibilities. You can't cancel (or at least reduce) room modes because there is only one position. And in my opinion force cancellation is widely overestimated. the vibrations produced by subs are negligible / don't interfer with the music. Just take a look at all the professional studio subwoofer. There is not one using force cancellation.
And concerning these infnity speaker, i can't find any proper spec sheet. I won't buy anything that is sold without at least the basic tsp.
I'll have to hunt for the link; made 5 of them (20 woofers).
Here are some of the pics, they are all the same, but 2 of the builds were single fold.
The $8 woofer were a buy out/gone, but I think they will be back. The page on right is available.....someone would have to check the design.
**Might find the 299114 on ebay, etc.
Yes Xmax is a big deal for subs, but so is distortion. I have used the Dayton subs and they are OK, ( Reference and Titan) but nothing like the Peerless XXLS in a 12. I too like sealed subs and two cabinets. If right next to each other is the best place, you can do that. If you build them in one box, you can't split them.
Yes of course the Peerless XXLS is a great driver, but you still have to consider the price limit of ShaQBlogs. And even if the XXLS got lower distortions while doing high excursion, the two Dayton will be stressed less because of the higher over all displacement volume compared to one XXLS. And ShaQBlogs can't afford two of them.
I could write a lot more, but due to my limited language capabilities concerning technical English i would just take too much time.
And tvrgeek, your example is exactly the reason why no one should by cheap stuff. You get what you pay for.
In Germany we have a saying: If you buy it cheap, you pay twice.
I think the daytons are well priced but not cheap and one of the best options for the limited budget of ShaQBlogs.
And before forgetting it, remeber buying the 8ohm version if you want to use poth driver in parallel. Otherwise the impedance will be two low for most of the amps.
I did some more reading n forums, and it looks like a few have tried this for home use and it has worked out really well as long as it's not pushed too hard. If it comes close to a TC Sounds Epic 12, then should be good enough for a first build. Since it is cheap, why not try this for the first DIY sub?
If this goes better than what I expect then maybe will upgrade later.
In India we have a saying, If you can buy it, then you can sell it. There is always a sucker or two out there, we after all have a billion people!! ;)
Thats a good one. I have to keep it in mind :D.
Concerning the Infinity subs. Go ahead and try it. But make sure to build two seperate housings. If you want to, you still can stack them together, but keep at least the possibility to have a multisub system. Or you can use cheap particleboard for the first try, and if you don't like it, throw the boxes away and construct a new one. And one thing, try to brace the box (like this: http://img178.imageshack.us/img178/120/wohnung017iv5.jpg)
Have a nice weekend.
Grüße
Martin
