DIY Tweeter grill....any ideas?
I'm almost done with building a couple of full range speakers. They will use two Dayton Classic 12's and a Dayton silkie. I have grills for the 12's but nothing for the tweeter.
Any simple DIY ideas to make some type of grill to protect the tweeter dome?
I had considered using a 4.5 speaker grill. But I may not have enough room on the box.
Get a propane torch, some copper mesh, and some thick wire. Bend the wire into a circle, solder. Solder a circle of wire mesh to it. Simple!
You can get aluminum mesh for screen doors really cheaply at hardware stores; heavy-duty copper wire is also availible.
