WOW !!!!
Thats absolutely beautiful.
Did you make the bearing part yourself or did you buy it ready made?
Thank you! I made everything except the motor. In an earlier thread, I posted a lot of info, including design sketches, and you can see there how the bearing is made. As far as the bearing is concerned, I stayed with the original plan, but I ended up making the 2 bushings out of Nylatron, a hard Nylon impregnated with Molybdenum, a lubricant. I'm using a light oil as well.
That thread is here:http://www.diyaudio.com/forums/showthread.php?s=&threadid=50913
I was able to use some leftover material from jobs that had been finished at work. I did purchase the bearing shaft from McMaster-Carr for $9 + shipping. I think that if I had to buy everything (just the bearing parts), it would have been around $75.
Colby
Colby
Well you cant buy anything cheaper than 200-300 $USD.
Does anybody know of a good TT that has a good bearing and can be used for DIY?
I mean if you buy it used of course at a good price.
- Analogue Source
- DIY Turntable is completed- pics here
