I changed 300b tubes with new ones after the tube amp was unplugged from the wall for a while, and smoke started coming out from the tubes,then I turned it off and unplugged it, I made sure all the tubes were plugged in the socket before turning it on. Then I tried it again and hear a very strange noise coming from the amp. So I took them out and then I noticed brown burn marks at the top of the tubes. I put the original ones back in and they didn't burn but I heard the strange noise coming from the tube amp so I shut it off immediately. What should I do? Is this could be caused by a bad tube socket, or just a bad solder point.. anything else that could cause this problem?
thanks
thanks
Some new production 4-pin sockets have holes that are large enough to plug a tube in the wrong way. Could that have happened?
my first thought too ,kyle, i hate to say it, i've done this! when i saw the current meter instantly slam over to max rather than the slowish climb up , i shut it down! the tube plays to this day-good advertising for jj!
Judged by ectobia´s description I think that the tubes were possibly bad, plugged the wrong way around or whatever. This caused a short somewhere in the circuit - which still exists - and now the high current in the mains transformer "resonates" its windings, thus the "strange sound from the amp".
