DIY tonearm foundation so far...need so bearing fabrication advice
How do you make the PVC pivot bearing assembly work. What are the optimum mechanics behind that. I dont know if I can get the jewler an other parts somebody suggested. Pen bearings are easy to come by though. The arm is made of a violin bow. I am wondering the ill effects of bare exposed wire. What is the best way to run the wire? I dont wany any sloppy weight and pivot.
