diy stepped attenuator under 10$
You can get turrets and eyelets in various shapes and
sizes. You can rivet them in and sand it down to
a smooth and low profile.
Won't pads on the pcb suffice?
Untitled Document
Welcome to MEHTA EXPORTS - There is no substitute for Quality
The problem with pads that they are not meant for switch contacts.. will worn out fast ,
Using turrets is an idea ,any turrent come like a rivet?
something related i am searching.
something like i will plug in silver rivets and use .
I have developed the tight coupling arrangements .
Use any plastic as shaft.I am testing with a refill .Stopper is a piece cut from ball pen and glued to shaft with super glue.
once fitted the spring is compressed ,tries to expand and keeps the wiper and contact boards tightly held.
