Hi can you show me any links for this?i want a 2x20watt rms type of thing...
i DID have a site online,that used toshiba IC amps,but i lost it!!! it was a search in google,but i cant find it anymore
Thanks!
Thanks!
Most car cd players do about 20wrms, friends one manual said 19wrms. I'd suggest pulling a dead one apart and seeing what chip they use. They use the cars power rail, no power supply stage, channels are just bridged.
oooh if i can find one i will
my friend seems to accumulate used junk 😀
id just like to make my own,and then put it together so i know how it works etc..
(doing an electrotechnology course)
Jaycar do a TDA something (the only one they've got) that does 70w max of 14.4v (about 35rms). Its not really quality but does quite a good job.
Gutted a blown MEI car amp yesterday and found out that it uses the Toshiba TA8210 IC. This amp WAS fully functional when I put it into storage about 7 years ago. Try to connect it up and smelled something exotic. Open it up and saw a blackened resistor...... Will troubleshoot it someday.
Tripath also has some nice looking multichannel chips. Some of them are more or less specifically for car audio.
Have a look at http://www.st.com/stonline/products/selector/203.htm
This list contains many ICs amp: check out for the ones with 14.4 V "typical supply voltage" they're right made for car audio;
Bye
Bye
- General Interest
- Car Audio
- DIY small car amps
