Hi Everyone,
I have a pair of modded Wilmslow atc scm 100's, with the correct tweeters, port length and I even scored a pair of sl bass units recently. Now I have my old non sl drivers sitting on the floor in the hifi room and the difference in sound is to be honest nothing. I am wondering what to do with these extra drivers, I thought about selling them, but that is boring 🙂.
I was going to make some new cabinets for my Wilmslows the correct size, then I though why not go the whole hog and make new cabinets for the scm 200's 😀😀
I just need port dimensions and the hard bit the correct crossover, any help anyone?
Cheers
Chris
Cheers
Chris
You won't hear and difference between the bass units until it gets LOUD.
The 200s are active so you might as well do the same. Pick your poison (say miniDSP) and off you go. The crossover points you can get from the brochure (380Hz and 3.5KHz) I would bet money they are LR4.
Hope you are a long way from the neigbours! When finished that will pump some serious air.
I live on over 600 acres and my hifi room is purpose built with a soundproof air tight door my missus insisted on it 🙂. I was hoping to use my existing amps I have a 185w mosfet heavly biased into class A ( I built) that I have been using on my scm 100 clones and sadly my very good friend had just died and left mt his CJ premier 4 another serious amp so I dont really want to go active as I have two great amps to use. The scm 100's are active and passive are the hifi versions of the scm200's only active?
Cheers
Chris
You should be good to go then 🙂I live on over 600 acres and my hifi room is purpose built with a soundproof air tight door my missus insisted on it 🙂.
Cheers
Chris
the 200s are only available active in either pro or tower designs http://atcloudspeakers.co.uk/hi-fi/loudspeakers/tower-series/scm200aslt/
So you have a challenge ahead, but if you do it as a 2.5 Way to compensate for baffle slope based on the 100 x-overs you have, then shouldn't be too hard to do.
Not sure what you mean? Another option I could consider is build two sub woofers with the spare drivers, but if pos I would prefer just two speakers
Chris
Sorry. Often if you have 2 bass drivers then you do what is called a 2.5 way, where you roll in the second driver to compensate for baffle step loss. In your case as it's a 3-way, it would be a 3.5 way. Zaph|Audio - ZDT3.5 gives a good description, although in your case you can handle waaay more power.
To put it another way, the extra bass unit gives you 3dB more bass, so you have to attentuate mid and high by 3db less. which means it'll go louder with your existing amps as well as being able to handle twice the peak power.
I should also note that, based on some other threads there is some confusion as to if the wilmslow X-over is indeed right. If you can post the schematic for what you have, that would help people help you.
I dont have the schematic, but I have been looking for ages for genuine scm 100 crossovers.
Cheers
Chris
Here is some info for SCM50/100:
http://www.diyaudio.com/forums/mult...crossover-schematics-clone-atc-scm-100-a.html
Martin
Martin
Cheers
Chris
Ah I had missed that bit. I note you are enquiring about the pair currently for sale. If you can get those that will help a lot, although I still think active would be the right way to go, but that is just me.
interesting to read that those SL drivers make not much of a difference.
because everybody on Gearslutz is like: "OMG its night and day" and I was already doubtful about such statements
I haven't come across anybody on gearslutz saying that about the SL drivers, I have though come across some who compared passive and active ATCs who said things along those lines and going by my own experiences with otherwise identical active and passive speakers I'd be inclined to agree.
I can't seem to find the particular thread on gearslutz now but there is one where several people claim that SL drivers are worthwhile upgrading and "so much better".
Is anyone around here aware of what's the technically difference between SL and non-SL ATC woofers?
They are spoken to have a THD drop of -15 to -35dB but whats different?
The membrane? The coating? The magnet?
No idea what exactly is different but I suspect it has something to do with the motor rather than the cone.
Not sure how they would upgrade or why since ATC uses the SLs for all their own speakers and do not sell them to the public.
It might be possible if the speakers are over 20 years old ie purchased before ATC had SLs.
- DIY scm 200 crossover?
