DIY Remote Control for Everyone
Question for SY and the gang.......
How did all these digitally controlled preamps end up in the Chip Amp section? Just curious, not that my opinion counts.
"..........Careful with that axe, Eugene........."
Back to the topic at hand.
Jocko
I'm following this thread with interest and actually making something similar on my own with an SX28 and the same volume control chip.
Does anyone have a source for an sleek simple IR remote control? to use with this project?
Danny
DIY Remote COntrol for Everyone
Azira,
Unfortunately, I do not have a very cool remote control case for this. However, the IR section is designed to decode standard Sony TV remote control codes. This means that every universal remote control on the planet should work. Therefore, it would be easy to take apart any old remote control and build a cool looking case for it or buy a cool universal remote
Cheers -ALBQ
hi,
i modified Albq's program to work with my pic 16F74 using PicBasicPro,and i am stuck at one line of the program!!
here is the program and a detalied picture of the error :
program:
@ DEVICE PIC16F877, XT_OSC
@ DEVICE PIC16F877, WDT_ON
@ DEVICE PIC16F877, PWRT_OFF
@ DEVICE PIC16F877, PROTECT_OFF
DEFINE OSC 4
DEFINE LCD_DREG PORTB ' Set LCD Data port
DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTB ' Set LCD Enable port
DEFINE LCD_EBIT 3 ' Set LCD Enable bit
DEFINE LCD_RWREG PORTB
DEFINE LCD_RWBIT 2
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 1500 ' Set command delay time in us
DEFINE LCD_DATAUS 100 ' Set data delay time 100 us
DEFINE SHIFT_PAUSEUS 2000 ' Slow clock by an additional 2000 us
DEFINE BUTTON_PAUSE 50 ' Set button debounce delay to 100ms
declarations:
i con 254
clr con 1
line1 con 128
line2 con 192
IR_in VAR PORTB.0
IR_detect var bit
IR_pulse var word(8)
IR_word var byte
index var byte
TRISA=%111111
TRISB.0=1
CS VAR PORTC.7 : high CS ' Chip select pin
SDI VAR PORTC.6 : high SDI ' Data out pin
SCLK VAR PORTC.5 : high SCLK ' Clock out pin
prev var byte
counter var BYTE
mute var BYTE
tapemon var BYTE
power var BYTE
volume var byte
setting var byte
IN2 VAR PORTA.1
IN3 VAR PORTA.2
drc var BYTE
new var BYTE
old var BYTE
initialize:
old.bit0=in2
old.bit1=in3
pause 2000
volume = 0
LCDOUT I,clr
prev = 99
LOW CS
pause 10
shiftout SDI,SCLK,1, [volume\8,volume\8]
pauseUS 100
high CS
PAUSEUS 100
HIGH SDI
main:
gosub encoder
gosub ir_scan
goto main
ir_scan:
IR_detect = PORTB.0
if IR_detect = 1 then end_ir_scan
gosub startbit
gosub get_pulse_stream
gosub decode
gosub function
end_ir_scan
return
encoder:
new.bit0=in2
new.bit1=in3
if new=old then end_encoder
drc=(new^old)&3
if power = 0 then end_encoder
if drc = 1 then countdown
if drc = 2 then countup
countdown:
if volume=0 then continue
volume = volume - 1
old=new
goto set_volume
goto end_encoder
countup:
if volume=255 then continue
volume = volume + 1
old=new
goto set_volume
goto end_encoder
continue:
old=new
goto end_encoder
end_encoder:
return
startbit:
for counter = 0 to 15
pulsin IR_in,0,IR_pulse(0)
if IR_pulse(0) > 900 then startbit_detected
next
startbit_detected
return
get_pulse_stream:
find_stopbit:
pulsin IR_in,1,IR_pulse(0)
if IR_pulse(0) > 1400 and IR_pulse(0) <> 0 then decodebits
goto find_stopbit
decodebits:
pulsin IR_in,0,IR_pulse(1)
pulsin IR_in,0,IR_pulse(2)
pulsin IR_in,0,IR_pulse(3)
pulsin IR_in,0,IR_pulse(4)
pulsin IR_in,0,IR_pulse(5)
pulsin IR_in,0,IR_pulse(6)
pulsin IR_in,0,IR_pulse(7)
return
decode:
for counter = 0 to 7
lookdown IR_pulse(COUNTER), [400,800], IR_WORD.Lowbit(counter)
next
if (IR_word > 191) then main 'ignore codes to high
if (IR_word < 128) then main 'ignore code to low
if (IR_word = 128) then valid_code 'one
if (IR_word = 129) then valid_code 'two
if (IR_word = 130) then valid_code 'three
if (IR_word = 131) then valid_code 'four
if (IR_word = 132) then valid_code 'five
if (IR_word = 133) then valid_code 'six
if (IR_word = 134) then valid_code 'seven
if (IR_word = 135) then valid_code 'eight
if (IR_word = 136) then valid_code 'nine
if (IR_word = 137) then valid_code 'zero
if (IR_word = 144) then valid_code 'channel up
if (IR_word = 145) then valid_code 'channel dn
if (IR_word = 146) then valid_code 'volume up
if (IR_word = 147) then valid_code 'volume dn
if (IR_word = 148) then valid_code 'mute
if (IR_word = 149) then valid_code 'power
if (IR_word = 187) then valid_code 'Back - Tapemon
if (IR_word = 191) then valid_code 'Info
goto main
valid_code:
index=IR_word & %01111111
return
set_volume:
setting = abs((1 */ 8192) - (127 - abs(128 */ volume)))
LCDOUT " ", "Volume = ", dec setting, ".", dec1 setting, dec2 setting, " ", "dB"
low CS
pauseUS 100
shiftout SDI, SCLK, 1, [volume\8,volume\8]
pauseUS 100
high CS
HIGH SDI
LCDOUT i,192, "Volume"
LCDOUT i,201, "-", dec setting,".",dec1 setting,"dB"
return
function:
if (index ^ 21 = 0) | (power = 0) then complete
if (index < 10) then numb_keys
if (index > 10) then func_keys
numb_keys:
lookdown index, [0,1,2,3,4,5,6,7,8,9], index
if (index = prev) then complete
if (index > 2) then complete
prev = index
branch index, [S0,S1,S2,S3,S4,S5,S6,S7,S8,S9]
func_keys:
lookdown index, [11,16,17,18,19,20,21,59,63], index
branch index, [S10,S11,S12,S13,S14,S15,S16,S17,S18]
S0:
LCDOUT "P10 - input one"
LCDOUT i,clr
LCDOUT i,128,"Button One"
high PORTD.1
goto complete
S1:
LCDOUT "P11 - Input Two"
LCDOUT i,clr
LCDOUT i,128,"Button Two"
high PORTD.2
goto complete
S2:
LCDOUT "P12 - Input Three"
LCDOUT i,clr
LCDOUT i,128,"Button Three"
high PORTD.3
goto complete
S3:
goto complete
S4:
goto complete
S5:
goto complete
S6:
goto complete
S7:
goto complete
S8:
goto complete
S9:
goto complete
S10:
goto complete
S11:
index = prev + 1
pause 250
LCDOUT i,clr
LCDOUT "Channel Up"
goto numb_keys
S12:
index = prev - 1
pause 250
LCDOUT i,clr
LCDOUT "Channel Down"
goto numb_keys
S13:
if (volume >= 255) then complete
volume = volume + 1
goto set_volume
goto complete
S14:
if (volume <= 1) then complete
volume = volume - 1
goto set_volume
goto complete
S15:
mute = mute + 1
if mute = 2 then mute_off
LCDOUT i,line2,32,32,32,32,32,32,32,32,32,32,32,32,32,32,32,32,32,32,32,32
LCDOUT i,192,"Mute"
high PORTC.4
LCDOUT "mute on"
return
mute_off:
mute = 0
low PORTC.4
LCDOUT "mute off"
goto complete
S16:
power = power + 1
if power = 2 then power_off
LCDOUT "Power On"
HIGH PORTD.0
LCDOUT i,clr
high PORTC.4
pause 1000
high PORTD.4
LCDOUT i,128,"Hello"
pause 1000
LCDOUT i,clr
LCDOUT i,128,"MY TRUE"
LCDOUT i,192,"MASTER!"
prev = 0
pause 1000
low PORTC.4
goto S0
power_off:
LCDOUT "Power Off"
LCDOUT i,clr
LCDOUT i,128,"Good Bye"
pause 100
LCDOUT i,clr
pause 100
LOW PORTD.4
volume = 0
low CS
pauseUS 100
pauseUS 100
high CS
power = 0
return
S17:
tapemon = tapemon + 1
if tapemon = 2 then tapemon_off
LCDOUT "Tapemon - On"
LCDOUT i,192,"Tape Monitor"
high PORTD.0
goto complete
tapemon_off:
LCDOUT "Tapemon - Off"
tapemon = 0
low PORTD.0
goto complete
S18:
goto complete
complete
return
and i atached the picture!
Hope u can help me with this code...cheers.
Summary,
Suggestion was to build a remote controlled preamplifier using a Basic microcontroller such as a BasicStamp, BasicAtom or BasicX microcontroller. Although slower than a PIC or Ubicom, the controller can be programmed in basic using free downloadable software. The advantage of such a solution for the DIY community is that it takes minimal software knowledge to get it working and, can be easily modified at by the end user. This means that once a basic design is developed, people are free to build upon it.
Oh, on your question, was thinking more along the lines of IR remote but, hey - its for everyone so, why not
Cheers -ALBQ
Hello,
I would like to build this Controller, Would appreciate if you could pass the details of pcb layout, bom and any updates.
Thank you
