Hi Guys, I've been looking around for a bit, and this is my first post. I'm wondering if anyone has attempted a clone of the studio 100s... it would seem as if you could get close, due to simplicity of design/scan-speak drivers, square box, etc. I would be using these mostly for monitoring application. What do you guys think?
The only thing you would have to buy from ProAc would be the MidWoofer. They had it slightly modified and the Scanspeak 18W/8542 isn't the exact one. They are available from the ProAc rep at slightly more per pair shipped than at Madisound. http://madisound.secureserverdot.com/catalog/product_info.php?manufacturers_id=148&products_id=933
You can buy the tweeter at Madisound direct and the crossover and cabinet aren't complicated!
I think you could build them for less than half their cost new and with a few tweaks they will sound even better!
Good luck!
Regards//Keith
Good luck!
Regards//Keith
I have cloned it.
Scan speak 18W8542 and Seas KT26F.
Hi B.L.,
So how do they sound compared to the originals?
Nice job! Did you compensate anything on the crossover for the slight differences in the midwoofers? I wasn't sure whether the tweeters were Scanspeak or Seas. By the time you finished them what percentage of retail price did they cost you?
Regards//Keith
Regards//Keith
from a polish board:
crossover:
http://www.audiostereo.pl/forum_wpisy.html?temat=22481&p=1#k
cabinet:
http://www.audiostereo.pl/forum_wpisy.html?temat=33186&p=4#k
unfortunatly only in polish, but google-translation should be sufficient to get the idea.
crossover:
cabinet:
Anyone find an english version to this project. I would love to build this but I am getting a lot of clonflicting info.
What info do you find conflicting?
I briefly read trough that thread and there is a picture of original crossover with parts specs and proposed modification with SS tweeter and different network. The cab dimmension should be in pdf file which I did not open. The owner of the modified speaker liked the outcome and commented only positive changes like fuller midrange without a touch of dryiness and better highs.
Some similar designs (In English):
ScanSpeak 18W/8542-00 + ScanSpeak 9500/9700 - http://www.troelsgravesen.dk/8542.htm
ScanSpeak 18W/8542-00 + SEAS 27TFFC - http://www.troelsgravesen.dk/Studio101.htm
ScanSpeak 18W/8545-00 + Vifa XT25TG - http://www.troelsgravesen.dk/CSM.htm
ScanSpeak 18W/8545-00 and Vifa XT25TG-30-04 - http://www.troelsgravesen.dk/CSM_KIT5.htm
18W/8545-K00 and Vifa XT25TG-30-04- http://www.troelsgravesen.dk/CSM_KIT3.htm
yes i know for this project but i ask for project similar studio 100 with scan speak 18w8542 and vifa xt25tg 30-04 because i have those two drivers and think that is vifa excellent driver and with scan speak thear must be good speakers
thanks anyway
thanks anyway
Yees the Vifa XT25 (and XT19) are great tweeters. If you look through Troels designs there are some that use this tweeter and also other designs that use the SS 8452 midwoofer. You may be able to combine the 2 parts of each corresponding crossover to get close to what you are looking for. I think you may need to do a bit of work on your own part to achieve what you desire. The cabinet dimensions and port tuning are already done for you.
Hey there!
I am aware that this thread is kinda ancient but hope I am still lucky to get some answers here.
I have owned a pair of Proac Studio 1 MK2s and then wanted to attempt building the Studio 100s. So now I have some ScanSpeak 18W/8542-10 and Seas 27TFFC chassis laying around, cabinets are built (although not yet flush mounted) and I tried to assemble the crossover several times. I think I have the right values and did the crossover like this:
I also found this picture of a S100 crossover and have noticed that Tweeter - is different here.
So: tuning is completely off and I don't know why. Any ideas or suggestions what the problem might be? I don't think it's the flush mounting, neither the slightly different version of the woofer (-10 instead of -00). And is the Studio 100 really that bass light or is that also part of my wrong tuning?
Thanks a lot!
Johannes
Thanks a lot!
Johannes
Show us the x/o values, schematic, enclosure internal volume, baffle measures, driver positions on the baffle, and I'll have a look at it.
Crossover is not assembled at the moment but I did it the same way as followed:
2 x Solen Cap 4.7uF 400V
1 x Solen Cap 2.2uF 400V
1 x Expotus 9W 4.7Ohms
1 x 1.7mH High Power Ferrite Core Audio Inductor
1 x 0.3 mH High Power Ferrite Core Audio Inductor
all ordered from Falcon Acoustics
baffles are 404 x 202mm ; 241mm deep and made of 19mm MDF
about 10mm bitumen to every side and 30mm foam for damping
bass ports are 50mm internal diameter, cut to 130mm
Your part values are very close to the ones I noted for my Studio One Mk II years ago: the capacitors and resistor are identical in value, and my measured inductor values are pretty close to yours. So it seems the crossover didn't change much from S1 to S100, despite the change in position of the tweeter.
Alex
Alex
Hi Alex,
yes that's right AFAIK. Also biwiring is new but I did not biwire mine. I think the S1Mk2 uses the 25TFFC + 8542-00 and the S100 the 27TFFC + 8542-10, though I am not 100% sure.
- diy ProAc Sudio 100s
