DIY or Retail
So I've been doing a bit of research on new speakers and have come across some amazing DIY projects. I've been looking at Paradigm Signatures and PSB Synchroniy Ones and have set aside $4k as a budget for my fronts. While I've never built speakers before I have done quite a few DIY projects around the house and am intrigued about building my own speakers. As a first timer will I be able to make a decent set up that can match the SQ of higher end retail speakers? How do I go about deciding on a design and components (full range vs multiple driver, ribbon tweeter vs dome)?
Thanks for any info.
Welcome to the forum.
My answer to your question is "Yes". But as a first time builder you want to find a good project that is well known and liked and follow it. Your first build will be hard enough, don't try to design it yourself.
Start looking here and across the web for speaker projects that have a lot of successful builds. Define your speaker size, use and budget before you start. Have fun!
Well, if my initial budget was $4k for front speakers, what would be a good budget to start with? I am looking for floor standing speakers with the best sound possible. I've seen some things from Fostex and Audio Nirvana about full range drivers, and have read a couple of forum threads from Dennis Murphy who seems to like the RAAL ribbon tweeters. Do be honest, I don't even know what a good budget is to start with. If I say $1500 for a front pair of floor standing speakers, is that a good place to start? If this is my first pair of DIY does that mean I shouldn't expect good SQ? I know it will take time to build and I love working with my hands. Most of my projects are around the house, rebuilding a basement into and apartment, completely redoing the kitchen, turning the attic into a guest room etc... I understand that I should start with a more simple project, but will I be happy with resulting SQ? Also is there a good selection of plans that I could look at that are geared more for beginners? Again thanks for the welcome and advice! 😀
The most important thing you can do is use an existing design for your first project. You will not be able to do the engineering on a new design your first time out without spending a huge amount of money on tools, test equipment, software, multiple speaker drivers, and crossover equipment.
My suggestion is to look at these websites and choose a project that appeals to you.
DIY Loudspeaker Projects Troels Gravesen
Humble Homemade Hifi
Zaph|Audio
There are many designs for you to look at, you will find something that appeals to you strongly.
Any speaker project will require the skills to cut plywood (or mdf or other sheet goods) to construct the structure of the speaker. The Orion structure is fairly straightforward except for the side panels, which are best rough cut with a jigsaw or bandsaw and routed to finished dimension using an mdf template and flush trim bit. Mounting the drivers is like any other speaker project. One of the most challenging parts of the Orion project is finding the precision film capacitors for the analog signal processing module...this is helped by the new PC boards that accomodate the lead spacing of the more available brands. I haven't built Pluto but the structure certainly seems more straightforward than Orion. If you are considering either join the ORION/PLUTO Users Group ; Index page and read up on either or both. The members are very supportive in providing advice and counsel!
I'm not worried about the carpentry skills. I've redone enough kitchens and built enough cabinets that I feel comfortable in that aspect. I am worried more about the fine tuning and electronics. I currently don't have the equipment to measure the speakers to make sure they are balanced and tweek them if they're not. I have a soldering pen and have done some work but don't want to end up with a $4k paper weight. I have the time to build them just nervous with it being my first speaker build.
That is where an off the shelf design comes in - properly done all you need to do is find the sweet spot location for them in your listening room and balance the W-M-T response using your ears.
Full Disclosure
What size speaker? How far can you place it from the walls? What type of amplification?
I have been overseas for the last 2 years and my gift to myself is a new HT system. 2 weeks ago I was planning on getting Paradigm Signature S6's Emotiva XPA-3 to drive the fronts, and a Denon 4311 using the preouts. As I've been searching these forums trying to get up to speed after being out of the loop for 2 years, I've been turned on to different speakers and recently DIY projects. I'm probably going to be in an apartment for 6 months before moving to a house, but right now I have no idea what type or size of room I'll be in.
For what it's worth, I'd recommend a pair of the Fonken speakers with CSS subwoofers as a first set of speakers. They sound "very" good and can be built well within your budget. I would also recommend using enabled drivers, as it does help.
Best Regards,
TerryO
after looking at the different recommendations I've decided on doing a statement build. I will start with the monitors, then the center, and finally the sealed statements. In the end i hope to have a nice 5.2 setup. I know people recommend not straying from the design for your first build, but I am making a slight modification to the cabinet. There will be a slight curve, nothing major, just to make it my own. Thanks everyone for the help and suggestions, I will do the design on sketchUp and give you all an idea of what I am thinking of.
