Read this thread, especially post #5:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=126184&highlight=
There's no way to add a subwoofer inside this unit, it would need to be external.
While it's possible to do a passive sub, you'll get much better performance with a powered one. The price differential on the Parts Express site was a buck or two.
You could easily add wires from the internal speakers to the plate amp speaker-level inputs without cutting a hole, just pass them out the back through the bass reflex port.
However, this unit will no doubt give far better bass as-is compared to the unit you showed earlier, possibly enough to satisfy without mods.
If you're up for a real fixup project, here's a unit with a built-in sub and a bit more power - just doesn't work http://www.stootsi.com/store/item.aspx?item=81433349
It's for an iPod, not a PSP, but you can always go the aux jack route...
Driver_King, here is the smallest "subwoofer" I have ever seen
http://www.parts-express.com/pe/psh...-875&FTR=264-875&CFID=192849&CFTOKEN=95552386
I didn't say I was looking for a 2" though. I was looking at a 3" for the speakers I already had and was wondering what people thought of them. Sorry for the confusion. I may still end up reusing the current system I have for it (the pic I posted earlier is what it looks like) but may modify it so it can power a "sub." I also wanted to know where would be the best place to put it and if it was possible to put it in the case without building a separate enclosure and if it would fit.
- DIY mini speaker project
