Any two-core with common screen will work.
It all depends on how good your ears and turntable are - it could range from R10 to thousands!
Or you could use two lengths of single-core screened and run them both into the din plug (it will have to be thin cable then, to both fit into the din.).
Braided screens are the best, but most expensive. Then you get stranded copper screens, and cheapest are the aluminised mylar screens.
(Does the 5-pin DIN go into the tone-arm? Beware that some tone arm sockets LOOK like 5-pin Dins, but the pins on the standard din plug are too thick)
I actually bought some 'figure 8' (two single-core, individually-screened) cable and simply combined both screens on the ground pin of the DIN plug.
I may have confused you when I mentioned the turntable; the cable is actually to go into a Quad 33 pre-amp (the DIN plug), whilst the two RCAs are plugged into the TT.
I was confused about whether to use a four-core cable, or screened (as I have done).
Thanks for your help.
Steerpike said:It all depends on how good your ears and turntable are - it could range from R10 to thousands!
With a 33/303 i would stay closer to R10
- General Interest
- Everything Else
- DIY Interconnect: 5 pin DIN to RCA
