DIY faraday ring.
I have read a thread in here that adressed this idea but i didn't fully understand it. so i am off to restart a new one. a faraday ring..... couldn't you just take off your dust cap and place a ring made of copper (glue it) on the top of your pole piece and replace your dust cap? Or am i missing the big picture of how a faraday ring acts. i have read that a shorting ring acts to cancel out any magnetic field produced by the voice coil, directly or indirectly. any thoughts ideas or suggestions.
mike
I think you have a Faraday ring mixed up with an extended pole piece.
That would be easy to do, because both yield a symmetrical magnetic field.
I don't think you can DIY a Faraday ring, but I think it might be possible to DIY an extended pole piece. In fact, I was thinking of trying it myself.
What I was thinking of doing was to take a real cheap junk speaker, and putting it into a makeshift vented box. Then running a tone generator or test record down the scale until it gets near the Fb, or frequency of the ported box. At that point, the speaker shuold exhibit "suck-in" where it leaves the center of the voice coild and goes all the way in or out. It is very visible, and the sound of the tone changes noticeably.
Then I would remove the dust cap, and glue steel slugs or washers over the pole piece. Of course, their diameter would be slightly smaller than the pole piece's. Since a normal size woofer extends the pole piece about 5 or 6 mm, I would try to get washers that were about 0.5 mm, or 1/32 or 1/64 inch thick. I would then gradually build it up until the speaker no longer exhibits "suck-in" at resonance. Then maybe go one extra for good measure, since I am sure there is a range of lengths of the pole piece can be to prevent "suck-in".
If the experiment worked, I would try it on a slightly better speaker, etc., until I got some confidence in the process. Then I would try it on a good speaker.
I guarantee nothing, but that is how I would go about it.
If anybody has some suggestions to improve this, please post.
Maybe copper or aluminum slugs or washers? 😕
copper ring part. :2
In Audiotechnology Dk. copper ring called "Symmetric drive".
-Symmetric drive uses a copper ring placed around the enter pole piece.
-The driver obtains a wider useable freq. range with clearer, more detailed sound.
- Greather thermal power handling.
-With S.D. the rise time is constant no matter where the cone is placed - lowers intermodulation distortion.
-S.D. lowers the inductance of the voicecoil and creates a more consistent impedan ce response.
-S.D. typically increases the rise time in the higher frequ. by factor of 10!!!
-S.D. makes possible both full bodied bass performance and fast clear midrange reproduction
:clown:
jazzy
welly welly well! an extended pole piece is what it is then! could someone give me a laymans explanation of a faraday ring then? the extended pole piece thing is a great idea if it would work. so adding washers would extend the reach of the magnets control over the voice coil then? could you do it on the other end also? i am sure it would take quite an effort to cut out the pole piece, glue it onto a circle of metal and glue that onto a plate. whew! i just confused myself! anyways, this sounds like a very do-able idea! i have many many cheap drivers laying around from old speaker i could try this on.
This is how I think of it. Imagine yourself sitting in a small boat and holding onto a pier, pushing yourself away from, and pulling yourself toward the pier. If the pier is made of 1000 tonnes of concrete then it is going to remain almost perfectly still, but if it is made of sticks of wood poking out of the water then it is going to move back and forth a little; the opposite direction to you as you play physics experiments in your boat.
When the voice coil flux pushes (or pulls)against the magnet's flux, seeing the magnet is not infinitely strong, it's flux is reduced somewhat (or increased, depending on the polarity of the voicecoil flux). Now if we put a copper shorting ring in the airgap, the varying flux from our wobbly old magnet induces a current in this shorted turn copper ring (only while the flux is varying!). This secondary flux has it's own magnetic field which opposes any change in the main field. It doesn't make the main field any stronger, it just makes it resist sudden changes better.
Sort of like putting a really big capacitor across the output of a dc power supply. It won't supply any greater continuous amps, but sudden changes in load won't shake the voltage around very much. Or like a big flywheel on an engine. It lowers the dynamic "impedance" of the magnet.
Copper ring
speekergeek,
I,ve attached Jpeg of S.drive - only for better understanding!:angel:
Re: Stephen D
Stephen D said:
Ummm... can't see hows extending a pole piece in only one direction would accomplish much. :dodgy:
The problem is that there is more magnetic material on the inside part of the pole piece then the outside. When you extend the pole piece, you equalize the amount of magnetic material on both sides of the voice coil gap, hence the symmetrical magnetic field.
JBL and McCauley use a variation of the extended pole piece. They machine their pole pieces so that the part that is near the back plate is thinner-hence uses less material-than the part that is in the voice coil gap. Knocking a certain amount of magnetic material off the inside of the pole piece is the equivalent of adding some on the outside of the pole piece.
I understand the principle, and think there is easy to implement. I have cooper pieces, but wonder if instead of steel it's better to use the cooper (I don't think so) I'll try with my 24Euro woofer.
Keltic, thanks for the info about the method, seems very clever.
Re: Re: Stephen D
sreten said:
Have to agree with this. for any decent driver adding steel
washers will make the field less symmetrical, not more.
🙂 sreten.
Notice I said start with a cheap woofer in case it doesn't work, lol. 🙂
While the mathematics escape me, everything I have read says that the non-symmetry is caused by their being more magnetic material on the inside, (the part near the back plate) of the pole piece than the outside, (the part near the dust cap). The pole piece, which is made of magnetic material, achieves symmetry when just a few mm is added to the end near the dust cap.
JBL and McCauley use a variation where they shave off a little of the pole piece near the back plate end, making it thinner there. That is how they achieve symmetry.
Well, it seems to me, steel is magnetic too. Hence, my suggestion of using steel washers to extend the pole piece.
I don't think you do understand the principle, from what you say above.
A Faraday ring must be inside the voice coil, and there is no room for one.
Only way to do it is pull the driver apart and copper plate the pole piece.
Extending the pole piece with magnetic material will only work for an ineptly
designed magnet structure. Most cases it will make things a lot worse.
In this case the material must be magnetic, so copper cannot be used here.
🙂 sreten.
Eh?
If I'm right, pole piece ends in some "T" shape, being the gap in the intersection of the two lines of the "T". if we put some magnetic material beyond the vertical line, kind of a
(I)
I
with the new pieces between parentesis, the circuit would be more symetrical, wouldn't it?
Re: Re: Re: Stephen D
Simply put :
A manafacturer is fully aware of this and will design
the magnet structure for a symmetric as possible field.
I understand that faceting of the edges of the pole
pieces is the way it is done. If the centre pole piece
needs to be higher than the surrounding plate, it will be.
🙂 sreten.
Raka:
That is my understanding. I only mentioned the copper or aluminum washers when another poster mentioned mentioned seeing a copper piece on the end of a speaker's pole piece, so I figured, "Who knows?"
When it gets to these things, magnetism and electricity get so intertwined that I gave up trying to reason things out. Whatever the engineers say works, is good enough for me. If a copper or aluminum washer extension works, I would like to hear an explanation, but I am not going to go crazy if I don't get one.
Once you do a frequency response test and see a woofer go through "suck-in" near resonance, you will understand why it is important to have a symmetrical magnetic field, no matter how it is achieved.
