Can these be made easily? Boss say that using the wrong type can result in the end of civilisation.
A volume pedal consists of a pot mounted in a pedal housing that can turn the pot. The pot is then wired to a couple jacks. Nothing simpler. You can run it in the effects loop or in fromt of the amp. I can't imagine how it could ever hurt anything.
You can probably find a used Ernie Ball or even an old SHo-Bud for reasonable money.
