Received my 1712 chassis with the optional 2 mm top plate yesterday.
I have not had the time to assemble it yet, but from what I can see this chassis is really high quality!
I also ordered som polished knobs. Wow!! These are exceptionally well made, with an absolutely flawless surface! "I did not expect that", as Simon Cowell in American Idol would have said.
The chassis was very well packaged, and the polished knobs came in their own separate draw string pouches. (I suppose that the last word is not the correct one, but I think you all know what I mean.)
Shipment to Norway took only a few days. Highly recommended.
Mike does make great enclosures. Now where are the heatsink versions? I really need them to finish my Greg Ball SKA amplifiers! I really don't want an alternative since my CAD program is ready to engrave on Mike's enclosures. Is there any way we can help? Preorder a minimum to make it worth your while?
Oh well...Anand.
Oh well...Anand.
Hmmmm. How does your CAD engraving work?
It has to frustrating having a business. You run out of a case and people go elsewhere for everything. You order a bunch of something else and no one wants it! Still, can't be good to leave people "unfulfilled" There is no doubt that there will always be a market around here for cases with LARGE heatsinks. 😱
Sorry to not get back to everyone sooner, but I am super busy. It's possible that we could do a group order for the heatsink versions, but the price would be higher. The reason my prices are able to keep low is because of my bulk orders. To get a really good discount, you need to do a run of at least 100 chassis. Still... we can do allright with maybe 30 chassis, but less than 10 and it's just really expensive. Let's see how many people are interested in a preorder and I will see what we can do.
The reason I've not re-ordered the heatsink version is because I only have a slow trickle of orders for the other versions. I must have a steady sale of both for the business to work. So basically the sale of the normal chassis have not kept up with the heatsink versions.
FYI on the DIY-1712 model I am running out of two parts:
one left: blank black front panel version
two left: black ventilated top panel version
I still have a good stock of the other faces and the blank black tops. I have plenty of silver chassis all around.
1712HS chassis
Okay...now we're getting somewhere. What's the price of the 1712HS if only 10 are ordered? How about 30? How about 100? I remember it being ~$150 a piece. What costs are we talking now?
Mike, your chassis are great! My preference has been for a the black heatsink chassis with a silver or black front panel. Come on folks, let's preorder!
I'll be happy with (2) DIY 1712HS black ventilated chassis with either silver or black front panel. So we've got two so far.
Variac, my CAD engraving is all done on Front Panel Express.
Best,
Anand.
Best,
Anand.
I'll price these, but I think we can have a pretty low price as before. If I can get a preorder for at least 15 of the DIY-1712HS or DIY-1013HS, then I will make an order for 50 chassis. Do we have that many people interested?
I'm interested
Put me down for at least (1) 1712HS enclosure. I'll ask around to get others as well...
Best,
Anand.
Best,
Anand.
Hi eboz!
Is this the same heatsink as used before in the 1712HS? Because I hoped you would consider something more capable...
Cheers, Hannes
PS: I need to check first, but in case all fits, I would be interested in a 1x 1013HS and 1x 610 - but let me check first!
Cheers, Hannes
Err sorry I meant, is this the same heatsink as used before in the 1013HS? Because I hoped you would consider something more capable...
The 1013HS is a keen candidate for ClassA-beasts, but that would mean 200W power dissipation capability...
Cheers, Hannes
Cheers, Hannes
I'd be down for 3 1712-HS cases ... not being able to order a decent looking and built case is the only reason I haven't placed my order with SKA amps yet.
Is there a possibility of ordering the 1712-HS cases without the heat sinks? Then we could determine what our heat sink requirements are, especially with all the new F4 interest, and then pick our own heatsinks. We needed to drill the heatsinks to mount them on your original cases, so would not be too much more work, but would give us a bit more freedom.
I don't think the 1712 HS is near big enough for a 2 channel F4.
It would require a 1013HS I THINK
Or a new model: A 1712 Ultra HS 😉 17"x 12"x 6.1" tall
What are the options eboz? I can see how things get complicated fast, but around here there are lots of Class A projects that require a lot of heatsinking....
You are right. I was confusing models. But it is not clear that the Heat Sinks that I got with the 1013HS will make it for the F4, or an Aleph 30 that I was originally planning, so have been looking at retrofitting some other larger heat sinks that I have.
Maybe we need to work out a set for the various Class A projects and recommend them. The rest of the chassis is so perfect and well made, that we should match the heat sinks we need.
Craig
Craig
hayenc said:You are right. I was confusing models. But it is not clear that the Heat Sinks that I got with the 1013HS will make it for the F4, or an Aleph 30 that I was originally planning, so have been looking at retrofitting some other larger heat sinks that I have.
Craig
Craig,
I do have a couple of chassis with the cut-out for heatsink side panels. If you'd like one, just let me know and make an order for a normal chassis. I will sell it to you for the normal version price of course. Just make sure to order it with the black body because I only have black side panels for heatsinks.
Anand: (2) DIY 1712HS black ventilated chassis with either silver or black front panel.
Hannes: (possibly) I would be interested in a 1x 1013HS and 1x 610
TurboFC3S: 3 1712-HS cases
That makes maybe 6 so far.
If I were making a lot more sales and a higher demand for the HS version, I would develop a custom heatsink.
AND it would be of better quality than the heatsinks I used before, pre-tapped and untouched by human hands.
Order Sent
Sent you an order for those two chassis, Invoice 86. Will work with others to try to get you some specs for a custom heat sink that would work and try to drum up some more business on this chassis. They really are so well built that I hope to help you continue.
There are so many comments out there about the chassis taking half the time of a project and also many incomplete projects due to no chassis. You really are contributing here with some high quality.
Craig
Craig
I'll be keeping an eye on what you guys end up doing...I'll also be building an Aleph 30 in a few months (smaller projects first)...
Just wanted to let you know that if the 1712-HS aren't available within about the next 6 weeks, that I'm probably going to end up having to buy something else ... no pressure
heatsink chassis update?
Any updates on the availability of these chassis? Else, I might have to bite the bullet and go with someone else.
Thanks,
Anand.
Thanks,
Anand.
- Vendor's Bazaar
- DIY Enclosures LLC - a new chassis manufacturing company in the USA.
