DIY Eichman bullet RCA plugs
I made a set of these today using scrap oak and .9999 silver wire. They came out really nice ( way better than they look in the pictures) but I havn't had a chance to hear them yet. It took about 20 mins to make the two of them. I will do them over again real pretty now that I see they work.
See the originals here.
http://www.xs4all.nl/~rabruil/bullet.html
Johnathan
I was not aware of the 47 labs connector.
Now that I've seen it, I will try to copy that.
peter
The center pin is just a silver wire, bent at the back to keep it snug and bent slightly at the front to make contact at only one point.
I will also try to remove some of the contact area on the return wire to resemble the eichman a little closer.
I'm really kicking myself for not doing this earlier.
Version 2.0
It's like a hybrid between the 47 labs and the Eichmann. I am working on doing away with the center pin but I'm not quite there yet. It sounds really nice. At first listen a layer of glare on the letters S, F, and T has been removed. Doing one at a time and listening made me want to do the other one right away.
Re: NATURALS.
fdegrove said:
Personally I had good results with stripping/skinning caps, you may want to try that too.
Cheers,😉
Hi Frank,
I've been wanting to ask that question for some time now. What sort of sonic differences can be achieved from this? Is it something one has to listen hard for or something immediately palpable?
BTW, if one doesn't like the sound after skinning, how does one replace the plastic back?
TIA
:scratch:
SKINNING.
What you can expect is more openess, more natural sound.
The difference is quite obvious and immediately audible.
As I don't want to disrespect anyone's thread here, try a local search on " cap skinning" to find out more.
Moreover, as time goes by, I am more and more convinced that "natural materials" sound more relaxed and easy on the ear than chemicals. (Both are chemicals of course, it's just that nature seems to balance them better).
Don't get me wrong here, I am not the " Radio Nostalgia" kind of person.
I try to reason before I act...I am *very* lazy...🙄
Cheers,😉
You might find some more inspiration from the following patent
<a href="http://164.195.100.11/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&p=1&u=/netahtml/search-bool.html&r=25&f=G&l=50&co1=AND&d=ptxt&s1=tubular&s2=cogan&OS=tubular+AND+cogan&RS=tubular+AND+cogan">United States Patent 4,954,095
Cogan September 4, 1990
Cable employing tubular conductors </a>
Thin copper tubing is available here <a href="http://www.ksmetals.com/Cuttolength/default.asp">K&S ENGINEERING: 6917 West 59th Street Chicago, Illinois</a>
James
I ordered a few materials from McMaster-Carr and built this little number today when the material came in. I just couldn't wait until I got back to show them. I only know that they work but not how well yet. These are solid virgin teflon connectors made from 1/2" rod drilled out 5/16" and 1/8" rod pin the wire is 24AWG solid silver wire with a teflon jacket. The 1ft in length. Sonic reports to follow in a couple weeks. On problem noted so far: teflon is slippery! :clown: Next possible set will have some kind of grips machined in them so they are easier to get off the back of the unit.
I don't want to derail this discussion, but have you guys tried no connector? In my audio experience, every connector I get rid of, improves things. With no connectors moving your audio system becomes a major pain in the butt, but for simple systems it could really be quite good.
that said, I've got way too many connectors in my system.
Sheldon
