Samsung SyncMaster 520 15”
did someone dismantle this one because i can get one but it'a a lot of money so i don't want to rist like with this Hercules before. on the list we have samsung 510, 512, 530 but no 520. thanks.
V7 Videoseven L15PS is the same monitor as CMV CT-529A. It is very good, but out of production. YOu may still find one for less than €200 in Germany.
Just wondering if anyone had stripped a Dell 15" 1503FP for DIY?
Supposed to have good enough numbers (XGA res., 25ms, 300:1).
Thanks.
Thanks.
Hi Guys,
This is my first post and I am trying to help...
For teardowns of LCD's try
http://www.eserviceinfo.com/equipment_type/Monitors_3.html
Hope this is helpful ..
Cheers Kiran..
Cheers Kiran..
Hello
Been following this forum for some time know... Wealth of knowledge here.
I have just purchased a faulty ViewSonic VE500 off eBay for £30 including delivery.
Risky I know as it may not be just the Back light that is faulty BUT after testing with a light behind I can't see any Dead pixels and the LCD looks Good.
I understand that some Panels arn't DIY friendly because of the Driver board in the way and such..
I think this one IM(n00b)HO is though!!!
See Pics 😀
Wish me luck in my endeavors and if any you guys can recommend UK suppliers of Parts I would be most great full..
See Pics 😀
Specs: I forgot.....
15.0" color TFT active matrix XGA LCD
Optimum Res: 1024x768
Brightness: 250cd/m2
Contrast Ratio: 400:1
Response Time: 16ms
Response Time: 16ms
Sorry forgot specs.....
Response Time: 16ms
Can't seen to edit original post
Response Time: 16ms
Update for the compatible monitor list
Has anyone knowledge about the newest monitors which are compatible for the diy projector? I have tried Compaq TFT 450, but it has a bad FFC issue, so i need another monitor. Are the all LG models compatible and are the all Samsung models, example Samsung syncmaster 570B? Tom's hardware list for compatible monitors are some little too old monitors, even second hanc monitors are newer and
i'm interested if someone has a newer list.
Samsung 740N
G'day all
Just a quick message to let people know the Samsung 740N is easy to strip and mount onto an OHP. Its also very cheap. If anyone needs help with this lcd monitor dont hesitate to message me
Cheers
G'day all
Cheers
Hey all first post!
OK I tried an IC power 15" from walmart. Easy stip however is NOT suitable due to cable length.
Viewsonic VE150MB IS NOT suitable due to cable length
Viewsonic VG160 WILL work and stripping wasnt bad.
LG 1752S-FB Very easy strip and AG removal. No FCC issues. 1400:1 Contrast and 4ms grey to grey response. Great monitor!
how did you make out using ve500
Just wondering how you made out stripping the ve500 and any issues ,I am about to do mine this week . please let me know and thanks.
Fizzer said:Hello
See Pics 😀
In my experience they have annoying FCC issues... be careful. Also the specs are usually way worse than you'd hope.
Has anyone tried to strip the sgi gfx 1600sw monitor? The specs on this monitor is amazing. Would like to know if it's usuable before buying.
hi kennethjp,
No.
But I have tried the one is "videoseven 19 widescreen monitor". It's reviews are good and specifications are also comfortable.
No.
Dead lcd please help
guys, i have got a pretty big problem,
I purchase super brand lcd tv 9.2" res-800x256. With built in tuner, I purchase it for 4200/-Rs.(100$)
Vga & video connectivity
while stripping the lcd i destroyed it , The lcd is not working now.
i am in a fix now.
I was Making the projector for a friend, Now he wont be able to buy new set.
i have the controllers . i looked throughly and found that the controller is
based on techwell inc chip TW 8816.
I downloade the data sheet it specifies that the chip supports wxga . but the
lcd which came as package was only 800x256.
So is it possibe that i buy some other wxga lcd and connect to this controller,
will it work.
Kindly suggest if there is any compatible lcd, Will laptop lcd work .
laptop lcd's have great resolution in small size.
all the gurus present here please help.
i am in a fix now.
will it work.
- General Interest
- Everything Else
- The Moving Image
- LCD
- DIY compatible monitors list
