ken. that player will most likely cost him one years pay.
£1743 and up to £2436.
that kit would surely out of my reach
Or start with a regular CD player with crystal clock on the board (you need it to replace it with a better one at some point). You get the transport and case.
Then you throw away the analog/DAC stage, and replace with yours DAC and better clock.
This one is simplest and cheapest solution ever.
You get the case, remote and screen for free![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Just make sure the CD player uses a clock frequency you need for the DAC (256Fs for deltasigmas, 384Fs for some vintage digital filters).
And it doesn't have some "all-integrated" IC with integrated transport control and DAC on the same chip.
You can buy in Ebay a cheap Philips from the 700 series: CD-713/723/753, and also cheap TDA1543 DAC, and use as base for modify:
Philips CD 723 [English]
http://www.diyaudio.com/forums/digital-source/40361-why-philips-cd-723-bad-base-modding.html
http://www.ebay.es/itm/HI-FI-DIR900...mplifier_Parts_Components&hash=item519dca79a2
I am going to build two different units.
first the idea of using a cd player to use as transport and crystal is very fine- i am looking to do diy dac based on wolfson wm8470 chips which I have read to be highly detailed.
and second i have a Sony Mini compo system, with broken transport I will replace it with other transport and if possible add a Dac.
All the advices and guidance are highly appreciated . I dont want to buy kits, i can Make a pcb or get just a pcb and Find the components locally and proceed.
- Digital Line Level
- Diy CD Transport + dac
