DIY car audio class D 1500watt and above amp
That module has to do a bit more than invert the phase, It essentially turns one amp on for only the +half of the wave, and the otherfor only the -half. This set up does not double the voltage, essentially it doubles the power supply (available current). This bridging set up is real different from a class b bridge, where both amps work at the same time. While this bridging adaptor is neat, i doubt it would sound good as it adds a region of cross over distortion. In these amps if the power supply more closely matched the output stage then bridging it would be useless as no extra power could be supplied.
Ok thanks for the replies guys.
I will buy 2 JBL 1200.1's or maybe DEI2400's. These will give me more then enough wattage for the system.
One thing you should note about car audio is that there can never be enough decibels. Recently at the World champs in Nashville, 177dB's was reached and above. The idea is to keep it clean whilst at such levels, in order to maintain SQ.
Thanks again
It's called transfer function which gains upto around 12dB/octave when the sound drops below the wavelength of the vehicle.
So if the gain of the vehicle starts around 150hz at 37.5hz you have just gained 24dB....
Also using multiple drivers gains more db's again and on it goes especially if you are using ported or bandpass enclosures.
In the past i ran 2 10 inch subs with a low effiency of around 89dB/w/m from an 80 watt amp and got 129dB without using a ported enclosure or a bandpass enclosure...
Hope this helps you some...
I once attended the dB Drag Racing World Finals in Nashville, TN in November of 1998. Then the world record was set at 173+ dB. For those of you who are not familiar with this competition it consists of a competitor attempting to achieve the highest SPL possible within a 30 second interval. The sensitive microphone is place at the exact same positon for each vehicle according to rules. The placement is amount of inches from the passenger side pillar, y inches above the dash, and z inches from the front windshield (which is no longer glass but replaced with several inches of plexiglass which is reinforced with steel beams.) There are usually between 12 and 100 subwoofers in the vehicle (depending on the power class) and power amplifiers adding up to over 100,000 Watts in some occasions. This usually requires many many additional chain driven alternators and banks of gel cell batteries. The cometitors play short bursts of single tone frequencies attempting to achieve the highest SPL by hitting the resonant frequency of the car. Also, in order to conserve internal energy, each team (12 members) pushes on the outsides of the car in order to prevent the acoustical energy from transfering to the reinforced body of the car.
Keep in mind this is an exhibition and is show. Usually the teams of competitor's are sponsored by a major manufacturer or a local dealer. It is a popular exhibition that travels around the country and is neat to see. Wear earplugs...
But for me I prefer to use stero equipment for what is was made for....and to experience what the music was intended to be.
www.dbdrag.com
I always get a kick out of my old "train horn in the trunk" idea. I think it would be great fun. Especially at night nowhere near any tracks. I still have no idea how big a train horn is and im not sure i want to know... keep the old idea aroung for a few more chuckles.
recently I went around all the car audio shops in town to find a good big amp and speakers I tested a lot of them the 1500w 15"brahma 2ohm went up in smoke at 28vrms around 350w rms that was the only pricie speaker they would let me play with but the 1500w 15" sony went up at 26vrms the 1100w 12" 25vrms as for the amps the only ones they would let me test was the 2200w sony =27.6v rms 2 ohm and some pro audio fan cooled thing was ment to be 2600w was 26.4 v rms 1ohm
So as i found a car audio w rms is not worth the paper it is writin on.On top of the most car charging systems can only do 750w on a good day and the car has to run off some of that so you are not going to get any more than that with the cars power supply.so if you want good power try what i did rewind a 24v 90A geni to +/-/center tap 65v ac 40A so you have good power to start with and put a real amp on that. it is a lot cheaper and nothin around here even comes close to the sound my truck makes.
Car audio is mostly about wank factor. Brands like Sony, Pioneer, Boss etc. thrive on Max ratings and cheap products. Personly I hate the mainstream car audio products and most of thier owners. The amount of people that believe thier sony coaxial speakers jammed into thier door's whilst running off a .8% THD amp @ 30wrms (300w max....) sounds good is amazing. Several of my friends make thier own box and simply cut any old hole (!) for a port (They don't listen to my advice though i did make him download WinISD).
Apart from that, I quite like car audio 😀
My first DIY'd amp was two P3a's running a small SMPS (+-35v) and sounded quite well without the engine on. An inductor would have fixed the noise issue but it was only a prototype.
My current project may be of interest to you however. In theory it should be able to create well over 1kW (off +- 95v rails using a half bridge). The design is Ssamors (Sorry if I got that wrong) using a MAX4295 which driver a buffered IR2110 in order to switch a total of 10 output mosfets. I have something like 2500 amps worth of mosfets for the project.
I couldn't really care if I don't hit 500w rms, it's just for fun :angel:
I'll let you know in a few weeks if its possible😎
Your right about the wank factor! LOL,
But to be fair thats just one group of poor lost souls, normally 18 year olds that dont know any better yet.
That Air raid siren is a wicked idea! what could that do at 1 metre?
I have a V8 power WW2 air raid siren in my uncles farm, its None OP and its bigger than my car! this SLP drag thing sounds crazy and dangerous to me, that kind of db would damaged anybody hearing in a heart beat!
The strange part to me is that 99% of that power is turned into heat in there voice coils, so its like from 1000w of amplifier output only 10 watts is converted to acoustic pressure! nobody believes me when i tell them this fact.
so even a 10,000 systems only has 100 watts of energy being converted into pure sound energy so getting the most highest rated sensitivity speakers would be best, IMO, something like 101 db per watt not 90 db per watt, that make sense?
you are correct there its all about wank factor .I have never seen any car audio that can do what it says it can do and they mostly sound like **** to flash crome speakers that only suck power ,get hot and make **** disp sound.I mod around 2 (freinds ,friendrs of friends )cars a month that come from the wank audio shop(pro car audio,driving sound,ect)I get asked can you make it do more than just go boom boom
frost can you post the scematics for you amp I am playing around with something simlar size at the moment 1200-1400w rms 110-120v +/- rails but not for a car
also what are you going to power this amp with off the bat or geni
The amp schematic is here
ssamor hasn't posted here since last year so I don't know how well it worked. I'm going to create a daughter board for the MAX4295 so if it doens't work or I decide to experiment with UCD I can switch them whilst keeping the same power stage.
If you have a look in the Electronics and parts forum under "switching large amounts of fets" (I think), Subwo posted a schematic for the buffered IR2110 using complementry mosfets in an SO-8 package.
I'm powering it straight off the battery, for normal listening levels it probably won't draw over 30amps anyway.
Lucky I only just turned 17 then 😀
2 weeks and I'm legally allowed to drive on my own:bigeyes:
That's true but most speakers with a large Xmax (required for the huge spl levels) require large spiders and large surrounds which is all ontop of the heavy, rigid cone. All this drags down the efficiency dramatically. Have a look at http://www.ddaudio.com/caraudio/woofers.asp?series=9500e , I would consider those to be almost the #1 spl sub you can get (pathenon excluded). One of the last remaining car brands that rates in RMS over max :bawling:
