DIY BT Speaker Project- Interference Issues due to PS? - how fix?
I built a portable speaker out of wood with internal parts from Adafruit and Aliexpress. When powered on, with no music playing or at low volume there is an annoying electronic hum. When I disconnect the Digital BT player, and only amp is connected - the awful hum is gone. I have a conversation going with the Chinese via Aliexpress regarding the media player and they say it is because the Power Supply (+12V, 3s 18650 LIon with BMS charging) is too close to their "decoder" they call it. I'd like to find a way to get rid of the noise and have a clean signal (how do small BT speakers work when PS and source are closer- maybe shielding? Isolator? Any ideas or links? (I'd include a video of the problem but I don't see a suitable option for me through the media function).
Parts:
https://www.aliexpress.com/item/1005002835141520.html (Audio player BT, USB, aux etc)
https://www.adafruit.com/product/1752 (Max 9744 20W amp)
https://www.adafruit.com/product/1732 (20W speakers, nothing special)
I run it mainly on the batteries though it does run off a 12V plug in wall charging unit. Both plug in and batteries are connected to a BMS module to balance charge the 18650 cells (plug in) or discharge cells (during play). Plugging in to a wall makes no difference to the hum sound.
