DIY audio amp with tda8571j
I have a pretty good base in electronics, well I used to. I have gotten pretty rusty. Anyways, I am looking to build a home audio amp using the tda86571j quad amp chip from NXP. I have the chip, and the datasheet. But I am having trouble trying to figure out the supporting hardware needed, and how to bridge the circuit from 4 channel to 2 channel. The datasheet says its possible, but I'm not sure how.
What i would like to accomplish:
A simple 2 channel audio amp with a line in for mp3 players. Maybe a digital volume control. I have the speakers, amp chip, and power supply.
I am hoping to build this with parts from my junk bin. Cash is short, so I cant just go out and purchase an ots (off the shelf) version.
Well , the datasheet shows a typical application that only uses about 6 extra components so it should be pretty easy to figure out , there is even a PCB layout in the datasheet for this chip .....
As for bridging the 4 channels into 2 , I don't really think it is possible , The chip it"s self actually has 8 amplifiers in it that are already bridged to get 4 outputs so they can"t be bridged again for a 2 channel output , though you might be able to parallel the + outputs of 2 channels and the - outputs of 2 channels to get a 2 channel output but would need to add a low value(0.22R) but closely matched resistor to each output leg ....
Cheers
I saw the circuits supplied in the datasheet. I thought there should be more involved in an audio amp. So, I can insert power supply and audio in, and call it done? Other than a heatsink. Is it safe for the amp to ignore two of the channels?
Yes you can ignore the other 2 channels if you wish though you should short the inputs of the 2 unused channels to ground ....
Most of the circuitry is inside the chip , like the feedback network that would normally be set with external components with an opamp or power amp is already built into the chip .....
