DIY Airplay/DLNA
This is the CUhead Pro, a WiFi/Ethernet Arduino shield with Airplay and DLNA audio and also acts as an access point for WiFi ,with this shield you WILL be able to wirelessly push music and other sounds from your iOS and Android device and more. With very minimal work and programming you can have this versatile little guy up and running in no time. As the CUhead Pro is a shield, simply plug it into your Arduino based dev board and start transmitting.
Found this while browsing Sparkfun electronics. Sounds like a great devise to incorporate into any diy project. From what I gather from the data sheet! it will only stream 16-bit/ 48khz data.
