How to go about it will all depend on your design knowledge. This would not likely be a trivial design and build effort. Given the many possible solution paths, I can only offer you the following general advice:
1) If you are highly knowledgable - I'll assume not likely, since you are asking the question - then you could design the device from scratch.
2) If you are not highly design knowledgable, but are skilled in board layout and SMD component soldering, sesrch for a suitable free web schematic and build that.
3) If you are merely competent at soldering, I suggest you search for a suitable ready made kit (one with the SMD components already mounted to a PCB) to construct.
