• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
DIY 720p Projector use 10.6inch LCD(1280x768)
Neu, Original, Grade A Panel
Samsung OR TOSHIBA
Grösse: 15.4"
Auflösung: WUXGA
1.920 x 1.200
Grösse: 331.2 x 207.0mm , Pixel Abstand: (mm) 0.173
Farben:262K
Kontrast: 600:1
Helligkeit🙁cd/m2) 175
KM9E89BTVL HDMI KONTROLLER
Set: Kontroller Board, Menü Board , Inverter Board , LVDS Kabel
+Fernbedienung
Specification for AD-board:
Signal input: Analog RGB(0.7Vp-p),TTL Composite video signal
(1.0Vp-p +/-5%) S-video(S-Y:0.714Vp-p +/-5%;S-C:0.286Vp-p +/-5%😉
2-facher Audio Input
(PC Soundkarte& AV Audio input), HDMI YPBPR, SCART
Video system: PAL , NTSC , SECAM; T V Bands: VHF-L:49.75-160.25 MHz
VHF-H:168.25-450.25 MHz
UHF:451.25-863.25 MHz
VESA: DOS, VGA,SVGA,XGA,SXGA, WUXGA
Color: 24bit
Range of H FREQ 30-100KHz
Range of V FREQ 56-75Hz
Signal output:
Double LVDS 10BIT
Output Power for audio: 2x 10W
OSD: AUTO/EXIT,VOL-,VOL+,POWER,CH-,CH+ MENU (A)
OSD MENU:
Kontrast , Hellikkeit, Volumen, Mehrsprachig
TV: Kontrast , Helligkeit , Sättigung , Volumen, Auto-scan ,
Sprachen ,
Netzgerät Input: 12 V(+/-0.6V)
Leistung: Normale Nutzung
Spar Modus Stromverbrauch:
30W (ohne Dauerbelastung)
Abmessungen: 258mm (L) x137mm (W) x29mm (H)
Anybody built one of the 1920*1200 kits yet? How difficult/easy would it be to source the extra parts, such as the lenses and whatnot? I can't really tell what you get in the kit and what else is needed.
I'd love to try one of these kits though...
