[QUOTE[/QUOTE]Hi, I have replaced all the transisors and burnt out resistors on my Dixon AV6688 Amplifier when I switch it on both the relays click on, but there is still a voltage coming through the speaker posts ! The amplifier still goes into protection mode ! What could be the problem ? I have repaired many Amplifiers using the 2n5551 and 2n4501 transistors and their main output Transistors with positive results.
Hi, I have replaced all the transisors and burnt out resistors on my Dixon AV6688 Amplifier when I switch it on both the relays click on, but there is still a voltage coming through the speaker posts ! The amplifier still goes into protection mode ! What could be the problem ? I have repaired many Amplifiers using the 2n5551 and 2n4501 transistors and their main output Transistors with positive results.[/QUOTE][QUOTE
