Ok, so I recently purchased a used Hafler DH-200 off of e-bay. It usually works great but occasionally the channels become very distorted. After fiddling with the input jacks for a few minutes the music usually kicks back in nice an clear.
Where should I start to look to fix this. I was thinking of cleaning or replacing the input jacks since they look very oxidized. Could this be the culprit? What else might it be. It happens on both channels, but on one a little worse than the other.
Thanks,
Wes
Thanks,
Wes
BTW, it seems that the distortion is worse in the bass than elsewhere. I don't know if the means anything useful though.
Just a thought.
Wes
Just a thought.
Wes
Your instincts sound good to me- replace the input jacks, then see if it goes away. If that doesn't fix it, well, at least you've got new input jacks, they didn't cost much, you know one thing it isn't, and you can move on to the more complex possibilities.
Hmm, ok inputs are changed. Originally they had a resistor going from input ground to the main amp ground. Does anyone know the purpose of this??
Anyway, I removed these resistors because they didn't really fit well into the new input jacks, and things seem to be working fine, however, one channel still periodically alternates from working fine to really bad distortion. It will work fine for some time (like 30mins - 1 hr) and then go to distortion for a few minutes and then back...
Could this be a bad transistor maybe? It does it without any mechanical josteling, so I doubt that it is a faulty mechanical connection somewhere. Does anyone have any experience or suggestions about this??
Thanks,
Wes
Thanks,
Wes
It could be a bad part, a bad connection, or a bad trace. While music is playing, tap around the wiring and circuit board of the dodgy channel using an insulated probe. See if you can induce the distortion.
If that yields no results, try isolated shots of freeze spray to see if you can thermally induce it.
The input resistors may be important- I don't have a schematic at hand, but I would definitely put them back. You can use smaller ones if you have a mechanical problem with the originals, since there's miniscule power to dissipate.
this amplifier was "POOGED" a couple of times in Audio Amateur -- there are a number of mods -- I purchased one as a kit when they first came out, now one of the kids uses it -- must be indestructible.
Insulated
I'm just going to second the need for an Insulated Probe, emphasis on the Insulated, many stores probobly have it in your area.
While it may seem like a steep investment, it's well worth it, and you or your friends will probobly find use for it in the future again. Suck it up, buy it.
The input grounding scheme is critical, it must not be changed.
Looking at the amplifier from the back, the left jack is insulated from ground and a 2R2 1/2W resistor goes to ground.
http://www.hafler.com/techsupport/pdf/DH-200_amp_man.pdf
Read the instructions and assembley manual.
Help fixing dh-200
I've got an old DH-200 that was given to me from a friend. It has severe distortion in both channels.
The inputs are all oxidized, and the fuse caps are missing on the back (as well as the fuses, obviously).
I'd like to try replacing the inputs like wrl suggested. Does anyone know if I'll be able to find caps for the fuse holders? Would the lack of fuses cause distortion?
Here's the thing: I know how to solder, but beyond that I'm completely inexperienced at this type of thing. Frankly, most of the posts on this site fly well over my head.
I figure I can't electrocute myself as long as I don't open the thing up while its plugged in, but what about the capacitors? Do they hold a charge that needs to be released somehow (like when you work on a TV set)?
When people on this site talk about 'easy mods' do you mean easy for an experienced electronics hobbyist, or for anybody with a little patience and attention to detail?
What are the chances that this amp's problems are something a total beginner can fix fairly inexpensively, or would I be better off just picking up something cheap on ebay like an NAD 2100?
I'm thrilled to have an amp with such a venerable history, but I don't really need much (its just going to power a pair of Bose 901s in a second room), and I don't want to fool myself that I'm some audio expert, as fascninating as all this stuff is.
Sorry for the bonehead post, but I wanted to get a little advice before diving into this thing.
"Would the lack of fuses cause distortion?"
Yes.
"Does anyone know if I'll be able to find caps for the fuse holders?"
Try Radio Shack, sometimes the caps fit even though they look different. If you don't find some that fit, just replace the whole thing.
Yes.
Many of these were assembled from kits, by well meaning but unskilled assemblers. Often you have a loose nut on an output jack or a cold solder joint (which is what this sounds like to me). Tighten all the nuts on the speaker binding posts (you will have to remove the capacitors to get to them unless you have a small right angel ratchet).
If that does not help, wiggle things around to help localize to an area, then simply reheat all the connections in that area between wire and something, either the board, jack, and the parts underneath the board. The most frequent cold solder joints are on the wire connectors to the board, since these flex a lot and the wire is stiff.
I fixed a DH200 recently that had been a assembled from a kit. It had one channel that buzzed, died from time to time, then came on fine. Turned out to be a combination of a loose nut on a binding post, at least three cold solder joints and one leaky driver transistor. This thing was sold in 1980, so these problems had been lurking for years.
So, don't expect changing input jacks will be the easy fix. Most often you've got some tough debugging that should have been done at assembly time, but was not.
- Distortion in Hafler DH-200
