Distortion in amp after warm up
Old high resistance value resistors have been known to drift to higher resistance. resistors like 470K going to 700K or more. Enough to cause distortion, even with perfect vacuum tubes. With the power off, measure each resistor to see if it's within its marked tolerance value.
Make sure you dissconect one lead of the resistor from the rest of the circuit during you check.
