Distortion from Ports
Odd order usually sound worse for our ears than even order distortion.
So higher even order is better than higher odd order distortion.
No distortion is even better on the other hand hehe!
Why? Test it with a tone generator.
Use a 90 dB sinewave at 250 Hz, that's your reference.
Then, use a 90 dB sinewave at 250 Hz then add a 500 Hz sinewave at 80 dB.
Then, use a 90 dB sinewave at 250 Hz then add a 750 Hz sinewave at 80 dB.
What's worse? What's closer to the reference and what's sounding better for your ears?
I always thought that the harmonics, 2nd, 3rd, 4th etc in a FFT are always in decreasing order of magnitude, for example you might have the reference peak at 20Hz, then 40Hz @ -3dB (2nd), 60Hz @ -6dB (3rd). That would mean that the 3rd harmonic is -6dB from the reference, and far more inaudible than the 2nd harmonic. How then can you simply say that odd or even are better or worse? The odd harmonic 7 will be inaudible, I mean unless your SPL is high and decay of each harmonic is low.
The harmonics aren't always in a decreasing order of magnitude.
Some tube amplifiers for example due to their design cancel most odd order distortion so you're left with 2nd, 4th, 6th...
On the other hand, solid state mostly cancel even order distortion so you're left with 3rd, 5th, 7th...
Also even if the 3rd harmonic is less loud, it will be more audible because it's 3 times higher in frequency than the natural harmonic.
