hey all,
been searching for a few days on this topic, nothing totally dedicated that i can find so apologies if this has been discussed else where at length
have (2) L20.5 amp modules, and (2) SMPS to power them. is there a required distance they should be away from one another in the same enclosure? the amp modules will be mounted vertically on the enclosure's side heat sinks, while the SMPS will be mounted horizontally (so perpendicular to one another) and the space is somewhat tight, probably 2 or so inches from one another. will this be problematic?
I don't think you'll have any problems.
Although SMPSs have transformers, they are very small, and their stray magnetic fields are correspondingly small.
Much of the high frequency interference in a SMPS is generated as a direct consequence of the switching process, but amplifier modules seem to live quite happily alongside SMPS modules in domestic amplifiers.
