Looking to make a second amp, this time with some higher powered modules.
I am thinking of the Dissipante case, but was wondering what purpose/how well the heat sinks work if I am mounting everything to the base plate add-on?
I doubt the base plate transfers heat effectively to the actual chassis for heat dissipation, correct?
The surface area connecting the two is minimal, but depending on your needs the baseplate itself is a practical heat sink for low dissipation needs of bits and pieces. YMMV and is application specific, obviously.
