This schematic of discrete I-V converter was published in “Current-steering transimpedance amplifiers for high-resolution digital-to-analogue converters” by M.O.J. Hawksford
http://esewww.essex.ac.uk/research/audio
Opinions?
Opinions?
Why did discussion die here?
I find this paper very interesting. Anyone implement any of the circuits in there? Or why not?
I guess the basic topology is inspired from the Super Linear C ircuit of Japanese Pioneer.
I have recently re-designed/modifed the SLC circuit for my pre-amp,and got excellent sound which more like tube.
I will build the I/V circuit based on it next step.
That makes no sense. Error correction is a Hawksford invention, superficial similarities to other topologies notwithstanding.
I have one question;
In page 19 the author claims that the return path for the filter and I/V resistor (going to T1's emittor) is a current feedback path.
I don't really see the feedback here, I see this path as a return pth for the currents, making them go back in T1's path and so T1 operates in a constant current operation (nice!)
Where is the current feedback in here?
Did anyone build or even simulate the circuit?
On my simulations, it's drawing 60mA o both supplies (15V), that seems to be a bit on the high side...
Hi Bricolo,
I've simulated it in LTSwCad and have almost the same results: 62mA88 on +15 and 67mA19 on -15 rail, but I've place a 2mA J-fet current source for TDA1541A current offset nulling at the input.
aparatusonitus said:I belive so, otherwise DC servo won't be able to correct DC offset at output.
the servo is a true integrator so within its' linear range it will regulate output to 0V, no input offset nulling is required.
best
Guido got the point.
But I think there could also be a way to use it servo-free and to adjust some bias currents in order to get 0V output while the input is 2mA
Bricolo said:Guido got the point.
Yes, that should be possible, the trimming hand acts a s a servo 🙂
Yes, but after you adjusted it, you would see that it would drift over time and with temperature.
Jan Didden
Ha ! This discrete IV schematic looks quite like what I've been listening to in the last few years.
Try it, it's worth it.
Yes Guido, except from the fact that I didn't really think about the trimming hand as a servo but more as a one time setting 😉 Of course that's only possible if the DC doesn't drift that much with time/temperature/age...
Hey Peufeu, nice to see you here. Do you still live in Lyon? I'm there for a few months!
- Digital Source
- Discrete I-V conv.
