Discontinued foods YOU LOVE AND MI$$ LIKE CRAZY
Oops, white outside is mold, the bacteria is inside added to the meat mixture. Tisis a Dry Cure pepperoni not a modern pepperoni (short cure if any, possibly cooked instead of cured).
I may have to try making it myself.
I made Lomo a few years back, and the process is similar.
Lomo:
LaTienda.com - Lomo Iberico de Bellota - Dry Cured Pork Loin by Fermin
No, unfortunatly mine was not made from acorn feed spanish pig.
I sometimes wonder what part of "They don't make it like they used to" is due to the fact that they really don't due to changes in politically correct ingredients as well as probably actually banned ingredients, vs a change in our physical ability to taste.
For instance Strawberries. It is natural fruit so it should taste the same. But, no strawberry I've had in many years tasted as good as the ones I picked as a child. Close, but not quite as good as my memory indicates it should taste.
Oscar Meyer New England Brand Sausage
I liked to put a slice on an English muffin, with a slice of cheese and slice of tomato. Then toasted in the broiler for a few minutes. No substitute is quite the same.
And I'd buy some Fizzies if I ever found some at the store.
Different type of strawberry. The Everbearing ones you can grow around here gives that childhood memory back to you. The steroid cellulose ones in the store just don't cut it.
Did you know the Strawberry as we eat, isn't the fruit? The seeds on the outside of the red bulby thing are. There you go: another useless bit of info brought to you by yours truly. 🙂
Baxter's Mediterranean tomato soup before they changed the recipe. Golden Dragon cup noodles. These crisp snack type things called Punjabi Puri. Heinz Winter Veg soup. Branston Pickle fine chopped 'hot' version. Garners onion pickle.
Don Antonio's Italian restaurant. Why did you have to go back to Italy ;/
Hostess cupcakes? Twinkies? Come on now, aren't there any other computer scientists out there?
They're back -- same recipe sans bakers union. I think that Teamsters still do the routes.
I really do miss Hydrox cookies. Oreo's are much too sweet. Archway Dutch cocoa cookies are about the right measure of "sweet".
Further to this point, "Dutch" cocoa powder has disappeared from grocery shelves here in the PRNJ. It has a different pH than the Nestle or Hershey varieties.
I have a new sweet which is remarkable -- "marcepan" from Poland. WOW!
Not quite miss like crazy, but the factory making Rye-Vita crispbread in Australia closed down, and you can only get the "original", English made version now - and truly 'orrible stuff is the latter, a sort of crumbly, cardboardy tasting thing. So, had to move to another brand ... 🙂
